Drum brake recommends
Discussion in '1st Gen. Tacomas (1995-2004)' started by ElTaquitoJr, May 7, 2020.
  1. May 7, 2020 at 2:33 PM
    ElTaquitoJr
    ElTaquitoJr [OP] Well-Known Member
    01 Tacoma PreRunner 4 cyl
    I'm looking at replacing some of the rear end suspension and I'm thinking of starting with the drum brakes before I get started.
    I see some AcDelco drum brakes for less than 3 times the price of units on CB Toyota. The ones on my '01 DC have been there since day 1. Is this a time when going oem is a must?
    Wyoming09 likes this.
  2. May 7, 2020 at 2:37 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    For the last 10 years I have been going with Napa Ultra Premium brake products .
    It has no bearing on Napa that the delivery Woman looks really good
    ThunderOne likes this.
  3. May 7, 2020 at 2:43 PM
    ElTaquitoJr
    Based on solid reasoning :thumbsup:.
    I'll take a look at Napa's offerings. There's one not far from here but with my luck I won't find any eye candy behind the counter.
    Wyoming09[QUOTED] likes this.
  4. May 7, 2020 at 4:27 PM
    wjktdi
    wjktdi Member
    bill
    2001 Tacoma Prerunner, 2wd, extended cab
    You might check out Centric drums and brake products. I used them on my 4Runner as well as the pads and rotors on my Tacoma. I have the drums, wheel cylinders and shoes on the shelf in the garage.
  5. May 7, 2020 at 5:13 PM
    ElTaquitoJr
    The conclusion I'm coming to is that oem isn't critical.
    I'll look at both brands and make a purchase. Thanks guys.
  6. May 7, 2020 at 7:42 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Are you planning to replace the drums, or just the shoes? A Toyota OEM shoe kit is under a hundred dollars as I recall and replaces the shoes on both sides.
    Step by Step Tacoma Rear Drum Brake Shoe Replacement
    Links to all the parts and tools (no SSTs needed for this project), as well as a printable step-by-step guide to the job.
  7. May 7, 2020 at 10:19 PM
    ElTaquitoJr
    Drums and shoes to start. Then will be looking at replacing the leafs and shocks.
    My dad ended up in a fender bender once that resulted the bed developing an odd tilt so at some point the whole rear suspension is going to get replaced. I'm just starting slow.
  8. May 7, 2020 at 11:12 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Centric x2
    Should come in a black box
  9. May 8, 2020 at 3:54 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    It comes down to just what one likes .
    As long as the cost is all within the same range .
    Lots of Brake parts are being made in China they are still working on the quality control concept.
    I like to buy local for non specialty parts for the reason if something is wrong for any reason which happens all to often these days it can be fixed that day or the next
