drum brakes keep locking up....
Discussion in 'Technical Chat' started by ebayollis, Sep 4, 2010.
  1. Sep 4, 2010 at 7:38 AM
    ebayollis
    ebayollis [OP] MY DIXIE WRECKED
    josh
    spruce pine nc
    2017 tacoma trd sport ddbl cab 4wd auto
    I had a wheel seal go out and it leaked gear oil into my drum brakes ...well that caused my brakes to start locking. I fixed it about a year and a half ago and used 2 cans of brake cleaner to make sure I got all the oil out of it. well this past winter it almost got me killed...If your driving at reagualr speeds and apply the brake your fine...its when you start to slow down like when your stopping at a red light or parking that the right rear wheel locks up and literally almost throws you through the windshield...I spoke with the mechanic at work and he told me to check my e-brake thingy (lol) that goes through the back plate because it is known to sieze up...well it was and I unseized it and put some copper based anti seize in it...well this done nothing either...it still locks and drags the rear tire...he looked at my wheel cylinders, shoes rechecked my seal to see if was leaking again checked to see if my axle was bent and he said it all looked good except that one of my shoes was wearing on the bottom faster than the top and he said try changing the shoes....im going to do that today and i thought Id go ahead an replace both wheel cylinders and the spring kits....
    has anyone else had this kind of trouble with their truck...its got to the point where i hate to drive it casue it makes me so mad i get sick
  2. Sep 4, 2010 at 8:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    SOunds like a rear drum is not adjusted propperly.
  3. Sep 4, 2010 at 8:21 AM
    ebayollis
    josh
    spruce pine nc
    Ive had them adjusted 3 different times...i wish I had the cash for the disc brake conversion
  4. Sep 4, 2010 at 8:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The disak conversion actually gives less stopping power. Unless you change the booster, and other things. Are you having the same shop adjust them for you?
  5. Sep 4, 2010 at 8:25 AM
    ebayollis
    josh
    spruce pine nc
    I adjusted them once ( probably shouldnt count that one) My uncle did once (hes a mechanic) and the mechanic at work did....
  6. Sep 4, 2010 at 8:27 AM
    ebayollis
    josh
    spruce pine nc
    I noticed on one post a few minutes ago that your s'posed to put high heat grease on the backing plate where the shoes contact it..I have not done that since i cleaned them with the brake cleaner...think that might could be causing me all my troubles?
  7. Sep 4, 2010 at 8:55 AM
    tiger955
    tiger955 Well-Known Member
    Carson City
    06 Access 4WD
    trd suspension
    In my experience (34 yrs pro mechanic) I found that when shoes get saturated with oil, no amount of brake clean will clean them thoroughly. The oil impregnates the lining and you can only clean the surface. As the shoes get hot from use, and wear, the oil comes to the surface causing grabby brakes. It is not always noticeable looking at them but it changes the friction properties of the lining. The only way to correct the problem is to clean the drum thoroughly and replace the shoes.
    And don't go cheap on the shoes, a few extra dollars for quality shoes and they should last a long time on the rear of a Toyota truck.
  8. Sep 4, 2010 at 9:01 AM
    ebayollis
    josh
    spruce pine nc
    you know thought that as well...the pads look like they could be some what pourous
  9. Sep 4, 2010 at 4:47 PM
    2TRunner
    2TRunner Well-Known Member
    Ohio
    I was gonna say, you get any type of grease, oil, brake fluid, something like that on shoes and their done for.
  10. Sep 7, 2010 at 11:54 AM
    ebayollis
    josh
    spruce pine nc
    well i changed the shoes saturday and havent had a single issue since...thanks guys!
  11. Sep 9, 2010 at 4:25 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    It's great to hear you found / fixed that problem.
    I wonder why your brakes locked in the first place though... you ever notice the ABS system pulsing the brakes to keep them from locking?
  12. Sep 9, 2010 at 5:11 PM
    ebayollis
    josh
    spruce pine nc
    Mine doesnt have ABS for some stupid reason....the wheel seal broke/leaked on it one time and leaked
