Drum Brakes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeremy_283, Mar 24, 2011.
  1. Mar 24, 2011 at 5:28 AM
    jeremy_283
    jeremy_283 [OP] Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    How can you tell when they are worn?
  2. Mar 24, 2011 at 4:25 PM
    Tacozoid
    Tacozoid Well-Known Member
    Terry
    Katy Texas
    White Tacoma Pre-runner
    Billsteins,Texas tint. Blue Dash mod. Console mod. in Blue, Customized grille
    [​IMG] They squeeeeeel like a pig.
    Sincerely, Netty from "the Untouchables"
  3. Mar 24, 2011 at 4:27 PM
    Tacozoid
    Terry
    Katy Texas
    Seriously. If you pull up on your parking brake and there's a lot of travel that's a tell tail sign.[​IMG]
  4. Mar 24, 2011 at 4:56 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    He meant if you push it down with your foot. Auto's have the e-brake pedal.
    If you have less than 100K miles, there should be no reason why they'd need replacing. But if you want to check or clear out the brake dust, you have to pull the drums off. Good pics on using a bolt or two to remove the drums in this thread:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/146806-drum-brakes-spring-release-tool.html
  5. Mar 24, 2011 at 5:40 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    ^^ what he said ^^
  6. Mar 24, 2011 at 5:59 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    They never wear down... well not for an aweful long time anyway!
  7. Mar 24, 2011 at 7:53 PM
    bigcoffinhunter
    bigcoffinhunter Well-Known Member
    Agreed! I put 125k on my 1st gen and still had the original rear drums (50% remaining). Replaced the fronts around 90-100k.
