Drum Brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MTLTaco, Jun 5, 2009.
  1. Jun 5, 2009 at 7:33 PM
    MTLTaco
    MTLTaco [OP] Well-Known Member
    Montreal
    09 Double Cab TRD
    Was wondering how long before any maintenance is required? Thanks
  2. Jun 5, 2009 at 7:35 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    periodically, you'll need to clean and adjust the rears so that they wear even. when i had my 06.....every 15k,i would clean and adjust the rears.
  3. Jun 5, 2009 at 7:41 PM
    MTLTaco
    Montreal
    09 Double Cab TRD
    Just clean them every 15K. Thats it.? Thank Man
  4. Jun 5, 2009 at 7:42 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah, just clean them and make sure they are adjusted, you'll be good to go.
  5. Jun 5, 2009 at 7:46 PM
    MTLTaco
    Montreal
    09 Double Cab TRD
    Sounds good. Thank for the quick reply.
  6. Jun 5, 2009 at 7:47 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    anytime man.
  7. Jun 6, 2009 at 3:52 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Drum brakes should be self adjusting.... most vehicles the drum brakes will adjust when you're in reverse and use the brakes (I'm not sure if this is accurate for the 2nd gen trucks).
    Drum brakes don't require much or any maitenance (for the most part).
    Opening them up and cleaning (hose 'em down) is a good idea. While you're in there, inspect the shoe wear. Make sure the shoes are wearing evenly top to bottom.
    If they are not wearing evenly, then there's a problem with the adjusters. If you're under warrantee, I'd take it to the dealer and let them deal with it. If not - do some research on how the adjusters come off/apart. On other vehicles, I've taken them apart, cleaned them & lubricated them. I'm just not sure how the adjusters are on the 2nd gens.
  8. Jun 6, 2009 at 4:08 AM
    Robocop
    Robocop Well-Known Member
    Alabama
    09 4x4 Access Cab Gray Manual
    Not wishing to derail this thread however I have a similiar question that fits with this topic....hope it is ok to add it here.
    Is there any real advantage to drums vs disc? I can not figure out why Toyota continues to offer drums only while the rest of the free world has had 4 wheel disc for years. Is it simply a cost issue or is there some reason other than cost keeping Toyota with the rear drum set up?
  9. Jun 6, 2009 at 4:14 AM
    Janster
    Jandy
    Lancaster, PA
    Use the search button in the blue bar at the top. You'll get far better answers (that have already been discussed) from searching the forum than adding to this topic.
  10. Jun 6, 2009 at 5:05 AM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    I do not see an advantage. seeing as the Tacoma is not a sports car. and rear brakes do about 20% of the stopping. not to mention for off road drums are more of a sealed brake and less likely to be damaged by off road conditions. un less something gets in there. then it can't get out.
    Just my uneducated opinion.
    but yes, the search function is marvelous.
  11. Jun 6, 2009 at 4:01 PM
    Robocop
    Alabama
    I searched both here and google in general and all I really found were a thousand people asking the same question. It seems many were offering suggestions as to why they keep drum brakes however no facts were found in my searches.
    From what I did find it seems it is just a cost issue however again just curious.
  12. Jun 9, 2009 at 8:12 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    Sold my truck Jan '13... Still hang around.
    I found this thread searching for an answer to my e-brake question...
    How does one clean/adjust the rear brakes? I still have my '06.
    Thanks!
  13. Jun 9, 2009 at 8:45 AM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    They don't offer any real advantage over the stock drums. No need for them. It's just a cool point factor for the owner.
    As for the OP...the only real issue is checking the pad (shoe) wear. When they get thin, replace them. If they are wearing weird and uneven, troubleshoot them. Most rear brake pads/shoes wear slowly compared to the fronts. So if you are needing to replace the fronts, check the rears to see how they are, chances are they will be just fine until the next front pad change. That has been my experience with my vehicles at least.
  14. Jun 9, 2009 at 8:56 AM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    I have done nothing to mine basically the whole time I have owned my 13 year old Taco. I mean nothing other than checking them and dumping out the tiny amount of brake dust. They've lasted 220,000 miles so far and I swear there's hardly any wear on the shoes. Obviously they do little of the braking.
  15. Jan 9, 2011 at 7:04 PM
    SurfInferno
    SurfInferno Dont be stupid, its not smart.
    Dylan
    2015 trd offroad
    Has anyone attempted to change their drum brake pads (shoes)? My parking brake is hardly working and i have the feeling its because the pads have never been changed.
