Drum brakes
Discussion in '1st Gen. Tacomas (1995-2004)' started by LuCarp, Aug 30, 2017.
  1. Sep 2, 2017 at 4:12 AM
    LuCarp
    LuCarp [OP] Well-Known Member
    Tom
    2003 Tacoma
    I did back them off a little bit, the cylinders look good. I'm going to make a trip back to the auto parts store, these drums are not true.
  2. Sep 3, 2017 at 6:50 PM
    LuCarp
    Tom
    2003 Tacoma
    Took them back today and got a new pair of drums, no questions asked. That was the problem, they work great. Thanks for everyone's help!
    Fuergrissa likes this.
  3. Sep 4, 2017 at 6:12 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Went to oreilys and got some of their drums and shoes. I had such a horrible vibration that I took them off and placed the old ones back on. I buy OEM only for my truck. What I am replacing these days has lasted a loooong time. No reason not to for a few bucks.
    lukester78 and btu44 like this.
  4. Sep 4, 2017 at 6:19 PM
    LuCarp
    Tom
    2003 Tacoma
    Good point. If I factor in my time and the trip back to Autozone to exchange them, I should have bought one, this wouldn't have happened.
    JJ04TACO likes this.
  5. Sep 4, 2017 at 6:28 PM
    LuCarp
    Tom
    2003 Tacoma
    That was supposed to say OEM, not one.
  6. Sep 6, 2017 at 4:57 PM
    LuCarp
    Tom
    2003 Tacoma
    Well that lasted one day. Chatter is back, not nearly as b ad. I should have exchanged the shoes also.
  7. Sep 7, 2017 at 9:46 AM
    Glamisman
    Glamisman Well-Known Member
    I wonder if there might be a rotor issue also. When on the road by yourself meaning no one behind you, rotate and keep the handle rotated so that you can release it then pull the parking brake slowly and see if the chatter is rears only.
  8. Sep 7, 2017 at 10:11 AM
    LuCarp
    Tom
    2003 Tacoma
    I will try that tonight
  9. Sep 7, 2017 at 7:02 PM
    LuCarp
    Tom
    2003 Tacoma
    Well I changed out the front rotors and pads, everything seems nice and smooth.
  10. Sep 13, 2017 at 2:50 PM
    LuCarp
    Tom
    2003 Tacoma
    Here we go again, still have a little chatter and I'm thinking it might be the pads. I'm wondering if I should have exchanged them when I swapped out the drums.
  11. Oct 22, 2017 at 5:07 PM
    LuCarp
    Tom
    2003 Tacoma
    Well I picked up new drums and shoes at NAPA. No issues at all. I will bring the other ones back to Autozone and never go back. I can't believe that two sets of drums were out of round.
    wilcam47 likes this.
  12. Oct 22, 2017 at 5:15 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Ive seen that drums like to be out of round if the balance weights are welded on the outside of the drum instead of the face.. i usually avoid drums with the weight on the outside due to this.
  13. Nov 7, 2017 at 6:54 PM
    LuCarp
    Tom
    2003 Tacoma
    Follow up-
    Went to NAPA, bought new drums and shoes. Installed and adjusted just like I did with the 2 sets of duralast products from Autozone. They work perfectly!! Brought back the others to Autozone and got my refund. Lesson learned. The manager at Autozone did not even want to know what the issues were, they could care less.
  14. Nov 8, 2017 at 7:28 AM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    I just need shoes
    What do you guys recommend ?
    Dealer wants 04495-35230 $80 for parts
    Rock auto has them for $20
    What should I do ?
  15. Nov 8, 2017 at 7:40 AM
    #35
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    What brand are the Rock Auto ones?
  16. Nov 8, 2017 at 7:52 AM
    #36
    PROseur
    Pussy
    I can choose from centric to Bosch
    Ac Delco
    Power stop
    Is it just me not understanding the price ? On rock auto it says one UNIT is enough for two wheels
    Thus prices are from $13-$29 total
    I have no problems ordering Oem if you guys recommend
  17. Nov 8, 2017 at 7:56 AM
    #37
    PROseur
    Pussy
  18. Nov 8, 2017 at 8:04 AM
    #38
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    I use only OEM linings and have had great luck with Brembo rotors and drums. Trying to save a few bucks just isn't worth it sometimes IMHO. As the OP will probably attest.
  19. Nov 8, 2017 at 8:05 AM
    #39
    PROseur
    Pussy
    Thanks
    Ordering the OEM then
  20. Nov 8, 2017 at 8:58 AM
    #40
    rzgkane
    There is a forum member here named gunny1005 at Camelback Toyota. His name is Gary. He will get you good prices on OEM parts.
