Drum brakes
Discussion in '1st Gen. Tacomas (1995-2004)' started by LuCarp, Oct 3, 2017.
  1. Oct 3, 2017 at 7:05 PM
    LuCarp
    LuCarp [OP] Well-Known Member
    Tom
    2003 Tacoma
    I just swapped out my new drums and shoes on my 03 Tacoma. This is the second set because the chatter was so bad on the first set. Well the chatter is still there. Could the second set be out of round also? Seriously?
    Did the parking brake check and its definitely the back.
  2. Oct 3, 2017 at 7:08 PM
    GEENYUSS
    GEENYUSS Well-Known Member
    Colfax, CA
    1998 TRD Off-Road 3.4V6
    Icons, SPC UCAs, Solo Motorsports Mid Travel LCA, Fox 2.0, All-Pro Exp Leafs, 285/75/17 BFG KO2s
    did you grease the contact points on the shoes? ever resurface the drums? what brand shoes are you using? old hardware kit?
    wilcam47 likes this.
  3. Oct 3, 2017 at 7:09 PM
    LuCarp
    Tom
    2003 Tacoma
    I did grease the contact points. Autozone Duralast drums and shoes, new hardware.
  4. Oct 3, 2017 at 7:12 PM
    GEENYUSS
    Colfax, CA
    never have had luck with duralast, I replaced mine with some raybestos shoes and they are quiet and stop on a dime. I did replace the hardware and shoes and have the original drums.
  5. Oct 3, 2017 at 7:13 PM
    LuCarp
    Tom
    2003 Tacoma
    So it might be possible that the drums are out of round again?
  6. Oct 3, 2017 at 7:15 PM
    GEENYUSS
    Colfax, CA
    I've heard people say that the duralast drums aren't round to begin with. try getting them resurfaced, also if your hardware kit is worn out it could cause an issue although probably not. since rear brakes last so long anytime I change them I do new shoes, hardware kit, and brake cylinders
  7. Oct 3, 2017 at 7:16 PM
    LuCarp
    Tom
    2003 Tacoma
    Ill give it a shot, thx
  8. Oct 3, 2017 at 7:54 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    Duralast blows....mine were out of round off the shelf. Take them f#ckers back and get something else. Pads suck too.. at least from my experience
    GEENYUSS likes this.
  9. Oct 4, 2017 at 3:09 AM
    LuCarp
    Tom
    2003 Tacoma
    That's what I'm going to do
  10. Oct 4, 2017 at 5:01 AM
    NM Lance
    NM Lance Well-Known Member
    I bought a cheap set of drums (Centric or something). They were out of round right out of the box. I had to have them machined which cost almost as much as the drums themselves. I have never had a problem with cheap drums, but I will never buy them again.
  11. Oct 4, 2017 at 5:40 AM
    Toyota4x46921
    Michael
    Warner Robins, GA
    I have bad luck with pretty much everything. Last time I bought tires 2 were even out of round. There is a shop near me that will true the tires.....kinda sucks to do that to new tires but they will ride smooth.
  12. Oct 4, 2017 at 6:26 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    over that past 20 years
    and regarding toyota....
    you want OEM ride, get OEM parts
    otherwise deal with the problems cheap crap gives you
    ThunderOne, skeezix and rzgkane like this.
  13. Oct 4, 2017 at 7:57 AM
    rdp2provia
    rdp2provia Member
    Rick
    04 Tacoma Prerunner Ex Cab
    I just did the rears on my 04 with all new Raybestos parts from Rock Auto... Drums, shoes, wheel cylinders, and hardware kit... They actually work now and very quiet so far, less that 100 miles on them.
  14. Oct 4, 2017 at 8:09 AM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    Did you make sure that the mating surface of the axle flange was TOTALLY free of any rust or debris? That's often the culprit. It's a pain in the ass to clean them up but necessary.
    And I use only OEM linings and high quality rotors/drums. Brembo this time and they're great so far.
  15. Oct 4, 2017 at 8:33 AM
    GEENYUSS
    Colfax, CA
    I'm running raybestos on oem drums and work great as well. The key is making sure you buy good parts and change out all the hardware when doing shoes. They last around 100k miles. The old parts see a lot of heat and debris over time and are old. Also changing the cylinders is a good idea. If they are sticking then you won't have even pressure and cause issues too
  16. Oct 4, 2017 at 2:51 PM
    Toyota4x46921
    Michael
    Warner Robins, GA
    I went with raybestos also
  17. Oct 5, 2017 at 7:29 PM
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    Is your axle bent?
  18. Oct 7, 2017 at 4:17 AM
    LuCarp
    Tom
    2003 Tacoma
    Everything was fine before I did the brakes
  19. Oct 7, 2017 at 11:37 AM
    twblanset
    Todd
    Vacaville, CA
    2015 TRD OR
    Probably not the axle then.
  20. Oct 7, 2017 at 4:22 PM
    Glamisman
    Glamisman Well-Known Member
    the auto adjuster / bellcrank assembly is hyper critical to the performance of Tacoma rear drums... if it is not adjusted properly every time you pull the parking brake cable the auto adjuster is going to try and adjust the rear shoes... it will do this until the point where there is zero clearance between the shoe and drum and you are running around with the parking brake applied all the time, even if you have 10 clicks on the pull brake. Lift the rear end and try to rotate a tire, there should be a a small amount of free wheeling before the axle/spider gears prevent you from turing it more... if you cant spin it freely, even a few degrees this is the issue.
