Drum brakes ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gothtaco, Jan 9, 2023.
  1. Jan 9, 2023 at 4:32 PM
    gothtaco
    gothtaco [OP] Active Member
    05 Tacoma PreRunner sr5
    Conclusion that I most likely didn’t grease the contact points. What brake caliper grease do y’all use? Something maybe alternative to oem?
  2. Jan 9, 2023 at 5:37 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Sil-Glyde, Cerami-Glyde, SuperLube, I’ve even used the bearing grease.
    HondaGM likes this.
  3. Jan 9, 2023 at 5:44 PM
    Bishop84
    Bishop84 Well-Known Member
    Typically that means they are wildly out of adjustment as well.
    Tiny tab of grease on the 6 contact points, just lift the shoes up.
    gothtaco[OP], TnShooter and HondaGM like this.
  4. Jan 9, 2023 at 7:26 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Anything that says brake grease on it is fine
    TnShooter likes this.
  5. Jan 9, 2023 at 8:38 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    Silicone paste
  6. Jan 9, 2023 at 11:46 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Buy/use same stuff as fronts (high temp brake grease) and you are set for greasing front slides too. But any will work back there sparingly/lightly.
    Don't forget to free up and grease the parking brake shoe lower pivot post as they rust/freeze up over time.
    gothtaco[OP] likes this.
  7. Jan 10, 2023 at 3:33 PM
    gothtaco
    I assume it aint safe to drive like this lol?
  8. Jan 10, 2023 at 3:50 PM
    Bishop84
    It’s fine, the sound means they are working, just needs to be serviced
    gothtaco[QUOTED][OP] likes this.
  9. Jan 10, 2023 at 3:51 PM
    gothtaco
    Thank you bishop84
