Drum replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by seedy_tea, Jan 9, 2018.
  1. Jan 9, 2018 at 11:55 AM
    seedy_tea
    seedy_tea [OP] Well-Known Member
    chris
    Cape Cod
    2009 TRD-OR DC
    I had a weight come off a drum, and I believe its causing a vibration at highway speeds... is it OK to replace just the drums? or is a full brake job required?
    2009 TRD-OR 4x4, 113K miles. Shoes are currently at ~5mm (last inspection by Toyota in June). Any info would be appreciated. thanks
  2. Jan 9, 2018 at 11:57 AM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Might as well do the shoes while your in there... they are cheap, and if you use your old ones it could cause grooves in the new drums.
    grizquad and seedy_tea[OP] like this.
  3. Jan 9, 2018 at 11:59 AM
    seedy_tea
    chris
    Cape Cod
    2009 TRD-OR DC
    Ok. was hoping it could be an easy swap out, but if it'll cause problems i'd rather go the safe route. thanks.
    excorcist[QUOTED] likes this.
  4. Jan 9, 2018 at 12:04 PM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
  5. Jan 9, 2018 at 12:41 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    The old shoes will only cause grooves if they wear down to the metal. If they didn't cause grooves in the old drums, there's no reason to suspect they would cause grooves in the new drums. Yes, you can just throw on new drums, but I, too, would replace the shoes if they have over 50K. And you don't have to replace both if you don't want, just the one missing the weight. But do measure the other drum's run-out.
  6. Jan 9, 2018 at 1:31 PM
    grizquad
    grizquad Well-Known Member
    Massachusetts
    12 Tacoma TRD sport
    Plasmaglow Firestorm lights, Westin Bull bar, Flyzeye interior console lights
    Like the others said, you have most of the work done by the time you have the drum off, measure the shoes, and if they are below half worn, I would replace them. I don't know if the rear brakes have manual adjusters, but make sure the other side is adjusted the same as the side you put new shoes on.
    seedy_tea[OP] likes this.
  7. Jan 9, 2018 at 6:23 PM
    farmfromkansas
    farmfromkansas Active Member
    2014 regular cab base Tacoma
    How hard is it to remove the drums? The drums on my old 91 were really tough to get off.
  8. Jan 9, 2018 at 6:27 PM
    excorcist
    Reno, NV
    Easy, you use a bolt (m12?) in the threaded holes and it pushes the drum off.
  9. Jan 9, 2018 at 6:30 PM
    Bishop84
    Bishop84 Well-Known Member
    Weights come off of the drums all the time, unlikely the cause of the vibration. Check ujoints closely.
    b_r_o likes this.
  10. Jan 9, 2018 at 6:38 PM
    zjcas
    zjcas Well-Known Member
    Zach
    Hooksett
    2012 DCSB TRD Sport
    Fox 2.0 COs, Fox 2.0 Resi's, Wheeler's Prog. AAL.
    Had one of mine come off when installing my lift, one of my buddies who helped on the install tacked it back on. Did the job...
    b_r_o likes this.
  11. Jan 9, 2018 at 6:41 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The rear ends of these trucks never need brakes Lol! Weld the weight back on!
    zjcas likes this.
  12. Jan 9, 2018 at 6:43 PM
    NovaGTS
    NovaGTS Well-Known Member
    NOVA
    2012 TX BAJA SERIES
    I had a weight pop off mine too, I didn't notice any difference. Its a pretty minimal weight very close to center of rotation.
  13. Jan 9, 2018 at 6:45 PM
    zjcas
    Zach
    Hooksett
    2012 DCSB TRD Sport
    Only reason I noticed mine was one of wheels seized on a bit so took a hammer to it and heard the *ting ting* as it dropped, ignored it til I found it on the floor while taking the leaf pack apart
  14. Jan 10, 2018 at 4:38 AM
    seedy_tea
    chris
    Cape Cod
    2009 TRD-OR DC
    I dont have the weight. not sure when it was lost.
  15. Jan 10, 2018 at 4:39 AM
    seedy_tea
    chris
    Cape Cod
    2009 TRD-OR DC
    its a pretty minimal vibration too. but just annoying enough to want to get rid of it
  16. Jan 10, 2018 at 3:40 PM
    Chuy
    Lakeside, CA
    Silver Taco
    I wonder if sticking some of them super strong magnets would help? Look for anti-corrosion treated magnets as they will rust otherwise.
  17. Jan 10, 2018 at 4:22 PM
    seedy_tea
    chris
    Cape Cod
    2009 TRD-OR DC
    That's not a bad idea... Any clue approx what weight I would need?
  18. Jan 10, 2018 at 4:39 PM
    Chuy
    Lakeside, CA
    Silver Taco
    No since we don't know the size of the weight that fell off. Maybe get a few magnets and add the one at at time until the shimmy goes away. Then, as a permanent solution, weigh them and have a welder tack on a weight.
