Drum shoe wear
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Paul466, Oct 23, 2022.
  1. Oct 23, 2022 at 3:38 PM
    Kllrbee
    Kllrbee Well-Known Member
    Tim
    Bloomfield, WI
    22 Army Green DCSB Sport
    We dont need no stinkin 15 clicks! LOL...
    Always did it by feel. Turn the star wheel opposite direction just until theres the slightest drag.
    THEN...When backing up, the self adjuster (in theory) should adjust out just a slight bit more so theres no drag....just perfect.
    Does it actually work that way? Seems like it has for me on every drum brake vehicle Ive had. But I have no scientific data to back it up.
    The fact is that the self adjusting only works properly IF the initial and periodic adjustment is performed correctly.
    Edit...I believe you about your shoes being worn out at 21k, but man thats awfully short lifespan for shoes.
    Paul466[OP] likes this.
  2. Oct 23, 2022 at 3:44 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    My 2007 has 229,000 miles on it. I've replaced the rear pads once.
  3. Oct 23, 2022 at 3:44 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I’ve seen what you say be perfectly accurate on Jeep and Ford drums but the Toyota ones seem far better than either. As long as the parking brake continues to work on inclines with 4-5 clicks then I don’t plan to mess with it.
    The Jeep and Ford ones would stop holding the vehicle after a few thousand miles. They truly sucked and never worked right unless constant adjustments were made. Got rid of the Ford and swapped to discs on the Jeep.
  4. Oct 23, 2022 at 6:31 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Inspect them before you buy any parts. 50K is very low for front pad replacements unless you have been doing a bunch of towing, hauling, etc. The rear brakes are probably fine but you should inspect first.
    Taco y mas and Paul466[OP] like this.
