Drum squeek
Discussion in 'Performance and Tuning' started by Phil Dammit, Jun 12, 2013.
  1. Jun 12, 2013 at 12:55 PM
    Phil Dammit
    Phil Dammit [OP] Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    I replaced my drums some 30k miles ago and ever since then when I do light braking they sqeek like a dsmn air brake. Anyone else's do this?
  2. Jun 12, 2013 at 3:39 PM
    2TRunner
    2TRunner Throbbing Member
    Your Moms Place
    Clean, Lube and Adjust them there rear drum brakes.
  3. Jun 12, 2013 at 3:59 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    What do you think I did when I replaced? I have a manual so they adjust everytime I use the hand brake. Its def the shoes vibrating against the drum. Sometimes it happens when I don't have the brake pedal pressed.
  4. Jun 12, 2013 at 10:47 PM
    2TRunner
    Your Moms Place
    Probably forgot to lube or you've hit some decent water since you did the brakes and there is a little water intrusion/noise.
    I've been riding on squeaky brakes for awhile, I'm lazy. They were cool until I ran through some water, back to squeaky.
  5. Jun 12, 2013 at 11:15 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    I worked in a shop for 4 years, i know what needs to be greased on a shoe assembly to ensure that squeeking doesn happen. Also I live in Phoenix Arizona, no moisture in the desert. So why don't you do us both a favor and stop wasting our time because you obviously have no idea what you are talking about.
  6. Jun 12, 2013 at 11:20 PM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    My 2010 started to make noise recently. Not the grinding worn out noise but a light squeal / squeak some times with light pedal pressure.
    Have not done anything yet.
    Did read about some folks having a TSB accomplished to stop this.
    PK
  7. Jun 12, 2013 at 11:23 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Thanks PK, that's what I was wondering. Do you by chance have a link to the tsb? I can actually feel the vibration through the pedal when it starts to squeel.
  8. Jun 13, 2013 at 12:04 AM
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    Mine just squeaks when going in reverse after one full wheel rotation only when applying breaks. Wtf lol
  9. Jun 13, 2013 at 12:05 AM
    2TRunner
    Your Moms Place
    Getting kind of tired of your shit fella.
    On my end, guess what, I work in a shop to. Between working on an S10 (Starter, Radiator, Belt), the 95 Eldorado from hell (oddest noise on right turns only, starter was engaging with the flywheel making a card in bike spokes noise), An auto trans R & R on a 02 Civic and recharging my sisters AC today, by the time I got to your 2nd post in this thread, the 2nd half of it was seen, but didn't register.
    However, you should know, having worked in a shop and all, that CORRECT information needs to be provided for a proper diagnosis.
    This: I replaced my drums some 30k miles ago and ever since then when I do light braking they sqeek like a dsmn air brake. Anyone else's do this?
    Is different than this: Its def the shoes vibrating against the drum. Sometimes it happens when I don't have the brake pedal pressed.
    I'm sorry my diagnosis was not up to your standards, but when I was provided with incorrect and not enough information on a car that I certainly can't test drive....shove a stick up your butt.
    Why I don't usually try and help people with their car shit over the interwebz. You can't give the right info and I can't drive your shit.
  10. Jun 13, 2013 at 12:09 AM
    jmarquez808
    Jess
    Hawaii
    07 4x2 reg cab
    I won't be an ass if you help me with my problem :) he he any clue what's the deal with mine. Just sounds like normal break squeal but only after one full rotation while going in reverse with breaks being applied. I can go reverse with no breaks and hear nothing.with breaks applied it only squeaks once it seems once it rotates to that same spot. Seems weird. Any input would be cool. I work on my stuff myself but breaks are e only thing I suck with. Failed at bleeding my motorcycle breaks trying to get the air out and since then I'm weary to mess with breaks in anyway
  11. Jun 13, 2013 at 8:04 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    You're ti red of my shit, lmao. Cool story guy, yu were provided with correct information. You had all the information you needed. Squeel under light load. That would cancel out non normal breaking conditions. My location is on the left so your second response could have been avoided all together. Instead of assuming maybe you could have asked a few more questions like I did When I worked in Mercedes full time and avoided this.
  12. Jun 15, 2013 at 1:55 PM
    Front sight
    Front sight Well-Known Member
    SW Florida
    06 Prerunner TRD Sport
    Full OME 3"lift, LR UCA's,Destination 285/70/17's, 1.25 spidertrax, K&N drop in, 2nd filter removed, Weathertech liners, Toyota bed mat, reverse lights,Wet Oklee's, bedlights and other small stuff.
    Check your rear most u-joint. Mine did the same thing when it was going out. I thought it was my rear brakes until I got under the truck and had my brother -very slowly- back it up- a squeak every full rotation. Changed my u-joint and noise is gone.
  13. Jun 15, 2013 at 4:01 PM
    jmarquez808
    Jess
    Hawaii
    07 4x2 reg cab
    Thanks bro I'm gonna look into that. Mine only has 64, 000 Mules its an 07 is this abnormal at this mileage
  14. Jun 15, 2013 at 4:18 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    I will just say that the rear drum brakes on these trucks are shit for breakdowns, making noise, etc.
    Mine froze in place overnight this past January after a little moisture intrusion. Resulted in the e-brake not releasing and the shoes warping nex time I applied the stop pedal. Replaced them, mic'd the drum to ensure it wasn't fucked, and the damn things have made some noise ever since. Before anyone asks, yes, they were properly adjusted, lubed, etc.
    They sound like shit but they work. I will say this for the Tacoma; it's a truck and it likes to sound like one. squeaks, clacks, pops a plenty when you actually use it for something other than a glorified Camry. Holds up though.
  15. Jun 29, 2013 at 3:19 AM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    I would like to remove my rear drums to clean out all the accumulated brake dust. Does anyone know the size of the bolt needed to back off the drum from the axel?
  16. Jun 29, 2013 at 3:46 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2000 Prerunner TRD
    bilsteins, 2010 Tacoma 17" alloys w/265's, driveshaft mods, 1.25" hubcentric spacers.
    Instead of speculation and ruffled feathers, I have a suggestion, why not remove the drums and check your handywork, just in case something is amiss...I have reassembled stuff I thought was right, then found out otherwise...
    I doubt it is your driveline u joint, not affected by brake pedal pressure....
  17. Jun 29, 2013 at 5:00 AM
    moondeath
    moondeath Tyrannical leaders use 'Alternative Facts'
    Pa, Carlisle
    2013 TRD Sport DCLB 4x4
    5100 @ 1.75", 1.5" Icon Progressive 3 leaf, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I think this is the tsb number: T-SB-0236-12 for the rear brakes.
  18. Jun 29, 2013 at 4:48 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    No bolts hold on the drum... and I readjusted mine and sanded down the pads, bus stop noise is gone:D
  19. Jun 29, 2013 at 8:47 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    I posted too soon, they did not make noise up until I got home tonight. Looks like I need new drums and shoes to fix the issue, wearing a groove in the shoes and not wearing evenly.
  20. Jun 29, 2013 at 8:50 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    Its probably because you're retarded!
