Drum will not go back on
Discussion in 'Wheels & Tires' started by TWN76, Feb 4, 2022.
  1. Feb 6, 2022 at 8:17 AM
    TWN76
    TWN76 [OP] Member
    Tom
    2009 Blk Tacoma DBL cab 4X4
    I watched this video before and during my journey into drum brake land. Great video.
  2. Feb 6, 2022 at 8:42 AM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Never give up. :)
    Double check that the pistons are, indeed, all of the way compressed. They just look as if they are out too far.
    In fact, compare their appearance to the cylinder in the video you watched...
    CaptainBart45 likes this.
  3. Feb 6, 2022 at 12:03 PM
    TWN76
    TWN76 [OP] Member
    Tom
    I double checked that they were compressed all the way and just changed the new one out for another new one thinking it was a defective cylinder. Still no go.
  4. Feb 6, 2022 at 12:35 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
  5. Feb 6, 2022 at 12:43 PM
    CaptainBart45
    Bart
    Work in progress...
    Make sure you screwed the adjuster all the way down before you reassemble.
  6. Feb 6, 2022 at 1:15 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Remove the master cylinder reservoir fill cap to allow the fluid to easily move out of the wheel cylinder. That had happened to me more than one once swapping pads and rotors, damn pistons wouldn’t retract……..
    CaptainBart45 and TartanEagle like this.
  7. Feb 6, 2022 at 1:31 PM
    TWN76
    TWN76 [OP] Member
    Tom
    AND THE PROBLEM WAS.......... The parts store sold me the wrong cylinder. They sold me one for gen 1 Tacomas. I just installed the new, correct, cylinder and the drum slipped right on. Thanks for all the help!
  8. Feb 6, 2022 at 1:54 PM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    :annoyed::annoyed::annoyed::annoyed::annoyed:
    TWN76[QUOTED][OP] and gsubioguy like this.
  9. Feb 6, 2022 at 5:32 PM
    CaptainBart45
    Bart
    Work in progress...
    Congratulations! I haven't touched a drum brake since the early 90's and I didn't really care for those jobs back then. I had a great mechanic working beside me that I could always ask WTH?
    TWN76[OP] likes this.
  10. Feb 6, 2022 at 9:15 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Glad you got it figured out.
    Getting the wrong parts happens way to often any more.
    Any more i compare the parts coming off to the ones going on real close.
  11. Feb 8, 2022 at 6:40 AM
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    My general rule of thumb when doing drums is work on one side and leave the other side alone as a reference!! Not many drum setups are the same and rear brakes, especially drums, last so long that it's easy to be out of practice on them. Many rear drums on our trucks don't require any replacement of parts for 150k-200k as long as they are cleaned and lubed occasionally. Usually rear brakes really only do about 10-15% of the braking most of the time anyways. Which is why doing a rear disc brake conversion is not really a big upgrade IMO. Heck in areas with salt on the roads the rear disk becomes corroded since the pads aren't clamping as much, causing vibration/noise due to the corrosion build-up on the rotor surface and requires the pads/rotors to be replaced pre-maturely anyways, so in that case it's actually more frequent work than drum brakes.
    Captqc and SR-71A like this.
  12. Dec 29, 2022 at 10:38 AM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    just starting my drums...godspeed
