Drums are "Out of Round" on brand new Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thelonius, Oct 21, 2010.
  1. Oct 21, 2010 at 11:53 AM
    Thelonius
    Thelonius [OP] Member
    So I found out this morning that my brakes are pulsating because the drums are defective. Well, at least it's nice to know that the dealer was able to diagnose the problem quickly and they are being replaced with new parts. However, I worry that the bad drums may have caused wear on my pads or other parts (1500 miles on the truck now). Anything to worry about...or just chill out?
  2. Oct 21, 2010 at 11:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I wouldnt worry about it. Let the dealer fix it.
  3. Oct 21, 2010 at 11:58 AM
    98tacoma27
    Ben
    Not Beech Creek
    ^^That
    1500 miles isn't much on brakes unless you abused themn the whole time.
  4. Oct 21, 2010 at 11:58 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    ^^ this :D
  5. Oct 21, 2010 at 12:15 PM
    Thelonius
    ^^cool.
  6. Oct 21, 2010 at 12:18 PM
    iSTIZO99
    iSTIZO99 Well-Known Member
    Jax, FL
    2010 TRD Sport 4x4 DC/SB
    ^^warranty is sweet
  7. Oct 23, 2010 at 7:17 PM
    MMJ
    MMJ Well-Known Member
    Jack
    Denver
    2010 TACOMA TRD OFF ROAD
    Smitty Built nerf bars
    can some explain what pulsating is? is it the feeling like something is tapping against the brake pedal from underneath when braking?
  8. Oct 23, 2010 at 9:00 PM
    Beerrun
    Beerrun Well-Known Member
    Jon
    Spokane WA
    10 Sedan Sport LB
    Fog light rewire- debadge- front window tint- 5100's @ 1.75- Toytec 1.5 AAL- Avid sliders- 4x4 lighted switch- Sockmonkey decals- Truxedo low pro QT cover- Weather Techs- Back up light Mod. Diff. breather mod. OEM roof rack-Yakima bars. HomerTaco grill. Hella Black Magic Lts. WT vent visors.
    I wouldn't call it a tapping. More of a,,, pulsing, up down up down of the pedal. Maybe a lot, maybe a little, just depends how severely the rotors/drums are warped/out of round. When you apply the brakes, the caliper pistons push the brake pads against the warped rotor as it's turning. This causes the piston to pulse in and out. Brake fluid pushing back and forth to the master cylinder, making the pedal move up and down. I'm not a Tech. manual writer, so I hope this make sense. IMO torquing your wheel nuts will eliminate this, or at least reduce the problem.
