Dry Bearing Sound Tacoma 2007
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cdh55, Jan 16, 2010.
  1. Jan 16, 2010 at 8:44 AM
    cdh55
    cdh55 [OP] New Member
    07 Tacoma 4x4 standard cab
    I have a 2007 Tacoma standard cab 4x4 standard transmission...When I go above 65 mph and let off the gas I get a dry bearing sound from the drive train...Does not do it all the time...Does it in 4th or 5th gear...The dealer first changed the rear end...That did nothing...Then they lubed the slip joint and it was quiet for about 1000 miles...Then they replace the drive shaft and again it was quiet for about 1000 miles...When the noise comes back, it occurs with increased regularity....Does anyone else have this problem, or do I have a lemon????Thanks in advance
  2. Feb 15, 2010 at 12:44 PM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    They replaced the whole drive shaft, and the sound came back? That is odd.
    Maybe get a custom shaft instead of the Toyota one that keeps going bad?
    Mine is doing this too and has done so for awhile. Haven't gotten around to changing it. It's mostly just annoying.
  3. Feb 15, 2010 at 12:55 PM
    YuriKapustin
    YuriKapustin Active Member
    97 4runner LMT
    OME 3" lift, procomp 285x75x16 mud terrains, procomp 16x8 rims, cutom nudge bar and roof light rack, and much more
    From my experience, the carrier bearing will go bad on those when you lift it. or wheel a lot. Its a simple fix. Buy a new carrier bearig and bolt it in. From how explained it, the same thing happened to by buddies 06'
  4. Feb 15, 2010 at 12:56 PM
    drew02a
    San Antonio, TX
    No carrier bearing on regular cabs
  5. Feb 5, 2011 at 9:58 AM
    ecoterragaia
    ecoterragaia Well-Known Member
    Mid-Atlantic
    '06 RC, 4X4, 5 speed
    Sorry to bring back an older thread, but I've noticed my '06 regular cab 4X4 with the 5sp (18,000 miles) doing this too, exactly as the OP described. Looks like he's long gone and didn't post anything about whether or not he found out what the cause was.
    After buying this truck about 2 weeks ago, I changed out the rear diff and transmission fluids, as well as greased the driveshaft, among other things. The "dry bearing" or metallic grinding can still be heard/felt when lifting off the gas in 4th or 5th gear at >60mph. I only picked up it after a few days of driving it to work and back, it's barely audible above normal road noise.
    One thing to note is that the trans fluid was very black with a slight dark gray tinge from the super fine metal particles suspended in it (couldn't feel them, only see them with a very bright flashlight). It seemed much thinner than the Redline MT-90 I put in, and it had a super sweet smell rather than the gear oil smell.
    Does black fluid indicate overheating or burning?
  6. Mar 13, 2011 at 6:15 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    My 2010 does this occasionally. I don't think it has to do with the driveshaft or rear end as it only does it when letting off the gas in 5th not any other gear and only above 65. Maybe the noise is from gears spinning faster than the engine since 5th is overdrive. It only does it on my truck sometimes bit maybe I just get used to it and tune it out. Gonna check my tranny oil later. I only have 10,000 miles on the fluid since I changed it last so hopefully it is still clean.
  7. Mar 13, 2011 at 6:18 PM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    Have you checked the U joints?
  8. Mar 13, 2011 at 6:27 PM
    Yoytoda
    Roland
    completely stock
    Haven't taken to drive shaft off to check but if it's a u joint it would make noise in other gears. I've greased them every 10k or every other oil change. Usually takes 1-2 pumps.
  9. Jun 2, 2011 at 4:21 PM
    Yoytoda
    Roland
    completely stock
