DS2 Retrofit help
Discussion in 'Lighting' started by double dee, Feb 8, 2014.
  1. Feb 8, 2014 at 8:49 PM
    double dee
    double dee [OP] Well-Known Member
    Arizona
    I'm in the middle of trying to complete my retrofit. I'm trying to mount the projects into the bowl but the threads coming from the projector don't seem like enough to thread the nuts onto. Also the nut is way bigger than the hole so I am not able to tighten it. Am I doing something wrong?
  2. Feb 27, 2014 at 5:16 PM
    03is300ztk
    03is300ztk Well-Known Member
    Zach
    Somewhere in the hills NC
    07 Tacoma 4X4
    Grillcraft, with front and rear bumper/bed in the works.
    I had to call and purchase the round lock nuts so I would not have to cut the housing.
  3. Feb 27, 2014 at 7:12 PM
    Edpsx
    Edpsx Well-Known Member
    DFW
    13' Double Cab Limited MGM
    K&N Intake, Stainless Tube Steps, Pioneer 8500BHS, Coming Soon:, Morimoto H1 Mini, Viper 5704
    what kit is that ? My minis didnt look anything like that. You sure you are putting the washers in the right order and direction? I know if you put them in wrong it wont fit like that.
  4. Feb 27, 2014 at 7:13 PM
    03is300ztk
    Zach
    07 Tacoma 4X4
    Its the newest d2s 3.0. And yes he is putting it in the correct order.
  5. Feb 27, 2014 at 7:15 PM
    InSight Retrofits
    InSight Retrofits Closed
    The new one's shafts are shorter than the older ones.
    You have to cut your housing down to allow more of the shaft to come through.
