dt long tube ques?
Discussion in 'Performance and Tuning' started by Amo-cat3, Jul 11, 2010.
  1. Jul 11, 2010 at 10:26 AM
    Amo-cat3
    Amo-cat3 [OP] Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.7" URD Pulley, APR X1, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Alcan aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, m/t atz 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Going to put my dt headers on today and just wondering what high temp gasket sealer you all recommend to use, and after it's installed how long should i wait for it to set up before starting engine.
  2. Jul 11, 2010 at 2:47 PM
    c0astie31
    c0astie31 TACO SUPREME
    Dennis
    Long Island ny
    2011 4Runner Trail Edition
    A LOT
    Does use the sealent, just reuse your stock gaskets,
  3. Jul 11, 2010 at 7:22 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    I like FELPRO better. Stock is metalic. FELPRO is like a high temp crush gasket definately no leaks.
  4. Jul 11, 2010 at 9:35 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    5 hours later got them in and drivers side what a bitch. Nice lovely scratches on that side header. Haven't started her yet as i'm waiting for the permatex copper sealant to dry. If any of you used it how long did you wait until cranking your engine up.
    Honestly, did you all actually torque all the header bolts down. I just guestimated the required 16 lb torque. This was more frustrating than putting in the cam gears for my x-1.
    It's probably been 2 hours since everythings been bolted back.
    So please, if anyone can give me a recommendation on how soon i should start my truck (frickin suspense) or should I smoke a fatty and wait until tomorow - Maui style baby............................
  5. Jul 12, 2010 at 5:57 AM
    roxspin72
    NC
    Oh Yeah!!!
    Start it up drive for 50 mile and retourqe. should be good to go... enjoy.
  6. Jul 12, 2010 at 1:29 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    I love them! worth the pain in the ass install. nice rumble at startup, deeper louder tone with my mbrp exhaust. Nice punch and quicker response when pulling on to highway. Just gotta go do some redline runs to get the x-1 calibrated.
    I was told that with the x-1 i don't need the o2 sim, but my check engine light came on with code P0113. I cleared it with my scanguage, but can anyone elaborate if the x1 should keep the CEL light off?
  7. Jul 12, 2010 at 8:50 PM
    roxspin72
    NC
    Oh Yeah!!!
    This is what the code means:
    P0113 Intake Air Temperature Circuit High Input
    Check if any wires came loose. Also check your X-1 make sure it is seated to the ECU correctly.
    Now as far as CEL w/X-1, it will not allow a code to be thrown if you are running this MAP:
    Tta40.03A.F_295.zip w/the 3 after the F
    F3= APR hot calibration for vehicles without front catalytic converters.
    Good luck...​
  8. Jul 12, 2010 at 9:05 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Ok this is getting interesting. I've had the x1 for a year and had it mapped from urd with a K/n cai, and mbrp exhaust. I haven't downloaded xtune yet, but that file you sent me can i copy that to the usb flash drive then connect the flash drive to x1 usb to install map. I am going to download xtune now to my desktop and if you have time to tell me the steps to change maps that would be awesom. I would even paypal you something for your time.
    Thanks,
    Rod
  9. Jul 12, 2010 at 9:38 PM
    roxspin72
    NC
    Oh Yeah!!!
    LOL, no need for Paypal, thats what we are all here for. However I have never messed with the thumb drive. I download the Xtunes to my laptop. Save the file in your xtune software. You hook up to the X-1 via USB Cable.
    Here are some instructions from Scott at APR:
    Instructions:
    1. XTune not running.
    2. If you have the latest XTune.03A goto 3, otherwise
    a. Download latest XTune.03A from our website (http://www.aprpower.com/maps/XTuneInstaller.03A.zip).
    b. Use Control Panel to uninstall your current XTune
    c. Run XTune.03a setup.exe
    3. Use Windows Explorer to create a new folder under “Documents\Apr\AprCal\Tta40.03A” this will be next to your Tta40.02 folder
    4. Extract and unzip the attached new calibration into this new folder
    5. Connect your X1, engine-on, key-off
    6. Wait for timer to start counting, then drag and drop the new Tta40.03A.F3V_295.01 under the Tta40.03A node and drop it onto your X1 node located under XPorts.
    7. Progress bar will go to 100% and timer will start counting again
    8. Ready to go
    Here is Scott's email: Scott@AprPower.com He is very helpful
    There is also Gadget: info@urdusa.com
    If you dont have a Laptop, they will let you know your options. But the instructions above helped me. Just make sure you have correct MAP. The MAP in the instructions was for my Volant intake setup.
    Laters
  10. Jul 12, 2010 at 9:51 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    I've got a long nite shopping for a laptop now. The lap top will be filed under "Tacoma Mods" :). On an end note, i should be able to load a map to the thumb drive from my desktop then insert in to the x1 right? I'll try and call scott at apr tomorow. Much Mahalo
  11. Jul 12, 2010 at 9:58 PM
    Super Werty
    Super Werty Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    Yes but you have to rename it like so...
    X1.Tta40.03A.F_295.AprCal
  12. Jul 13, 2010 at 12:07 AM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Ok, I downloaded the updated xtune.03A to my desktop. Downloaded and unzipped your calibration file to to APR\APR CAL\Tta40 file. I then renamed your calibration file as "X1.Tta40.03A.F3_295.01AprCal".
    Put in my APR thumb drive to my desktop usb port and moved the above calibration file to it. So now I have the new calibration file on the thumb drive.
    So looking at the confusing xtune users manual I can now go to my truck turn ignition key to "on" position, insert usb flash drive to x1 usb port, and per instructions, "the X-One will flash the factory Malfunction Indicator Lamp (MIL) a calibratable number of times based upon the user settable tuning parameter "Config/CallD" in the map." So it will blink a few times and map is loaded and ready to start her up.
    Am I on the right track guys.
  13. Jul 13, 2010 at 8:41 AM
    Super Werty
    Arizona
    07 TRD Tacoma
    air and fuel
    sounds good to me;)
  14. Jul 13, 2010 at 1:44 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    So i spoke with Allan this morning and i got the usb flash set. Flashed my truck and got one flash from CEL to show it loaded. Per Allan I should of got 3 flashes. I left him a message about this, but truck is running awesome and no codes yet.
    I know you all probably load maps with your labtop so you don't pay attention to the CEL light blinking, but if yours does blink did it do it 3 times to show map was loaded.
    Lastly, i retorqued header bolts today after only 20 miles of driving and a few of them had loosened about a quarter of a turn. Still overall the headers are an awesome upgrade.
  15. Nov 16, 2010 at 5:01 AM
    ImthePrez
    ImthePrez Well-Known Member
    TN
    06 Prerunner TRD
    can you post a video of the sound of your truck? I want dt headers
  16. Nov 16, 2010 at 8:22 AM
    roxspin72
    NC
    Oh Yeah!!!
    Congrats....
  17. Feb 23, 2011 at 9:23 AM
    gotrdwoohoo
    gotrdwoohoo Member
    Bordon
    KY
    2007 X-Runner and...looking for more!
    - learn'n and look'n and play'n. Recently retired and thinkin about what to do to my X-Runner
    roxspin72
    I am researching the apr X1 as a friend knows a friend who got one and seems to like it. Heard it is hard to install though. Who are these guys? Is this thing really worth the cash? It seems it is a new company so there are not many folks who have bought this and before I make the investment I want to be sure of what I am getting. How many have they really sold? Anyone ever return one? I read they were sold out and my friend says they are hard to get.
    Bordon
    gotrdwoohoo@yahoo.com
