dt shorties, urd y-pipe, urd mk2
Discussion in 'Performance and Tuning' started by Justus, Mar 19, 2013.
  1. Apr 3, 2013 at 11:51 AM
    #61
    BradyT88
    BradyT88 Well-Known Member
    There you go. Just play dumb and act like you were only expecting like 8lbs of boost and like 300hp. Haha.
  2. Apr 7, 2013 at 6:09 PM
    #62
    Justus
    Justus [OP] fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    2 days.......
  3. Apr 7, 2013 at 6:12 PM
    #63
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
  4. Apr 7, 2013 at 9:29 PM
    #64
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    Haven't tracked my packages...I wanna be surprised when I get home.
  5. Apr 8, 2013 at 4:19 AM
    #65
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I gotta time mine with installation help...........im sure 4 hands are better than 2 installing these items.
  6. Apr 8, 2013 at 5:01 PM
    #66
    SoCalTacos
    socal
    so i received my long tubes, maf cal, o2 sensors today....no y pipe.
    theyre shipping it out on wednesday, so im at least another week out from install...cant wait.
  7. Apr 8, 2013 at 5:10 PM
    #67
    BradyT88
    Sweet! :jellydance:
  8. Apr 9, 2013 at 2:35 AM
    #68
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    What Brady said x2...........
  9. Apr 9, 2013 at 5:05 AM
    #69
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I sense POWA!
  10. Apr 9, 2013 at 5:59 AM
    #70
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I sense more noise and butt-dyno assessments :D:D:D
  11. Apr 9, 2013 at 5:59 AM
    #71
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I did just rip a huge fart.......
    Do that count as boost?
  12. Apr 9, 2013 at 6:17 AM
    #72
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I've called three shops and haven't found a dyno, despite promising leads online.
    I don't think I have made a single hp claim on the butt dyno, and don't intend to.
    Living on the central coast has great benefits....performance shops and dynos are not 1 of them sadly. :(
    Find a dyno and a place that can tune within an hours drive of 93401, and ill go.... the closest I found here was a smog only dyno, and the guy who craps on anything "import".
  13. Apr 9, 2013 at 6:19 AM
    #73
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Runnin low on options, and no vacation time till august....any help is appreciated
  14. Apr 9, 2013 at 6:45 AM
    #74
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Hey, just kidding! That's why I added the smileys. I've been watching this thread and am anxiously awaiting the results as I'd like to see some results that have some semblance to reality.
    BTW, my opinion is that I'd run the setup you've bought, as is, with only the stock MAF cali map as given by Gadget for your mods. Get an ultragauge/scangauge/somesuch and watch your fuel trims. Only if the trims are off would I look for tuning.
    As for dynos, I assume that you've looked at the dynojet web page and found their list of dynos? Not sure if Mustang has the same type of list.
  15. Apr 9, 2013 at 6:55 AM
    #75
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Gotcha.... I heard mustangs tend to be off, so id rather stay away. Please correct me if im wrong..
    Got an ultra.... ill keep an eye on em
    Crap, I don't think I tried the simple "dynojet facilities" thing.....thanks!
  16. Apr 9, 2013 at 8:43 AM
    #76
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    My "understanding" is that the Mustangs are as good as the Dynojets, just that the Mustangs tend to output higher numbers. My feel is that as long as the dyno you use is consistent across pulls then use it, but if you want to make comparisons across dyno pulls and dyno types, then all bets are off. Operators, facilities and "normalization" curves that are applied make comparisons very error prone. I.e., dyno the same configuration on different days and you will very likely get different results, dynos are a measuring device and definitely have acceptable measurement error ranges.
    Now, this being said, note that I have never used a dyno,,, to cheap. My mods are low cost and the cost of a dyno just doesn't make sense to me. I'll stick with 0-60, 1/4 mile times,,, and yes, I realize the errors that can be attributed to this type of measurement to.
  17. Apr 9, 2013 at 10:09 AM
    #77
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    To add a slight correction, DynoJets usually read the highest. Then Mustangs, then Dyno Dynamics.
    DynoJet and Mustang dynos start reading the same around the 7-800 whp area. (Might be a lower number now.) At least with the older style DynoJets. The newer ones can be inertia or eddie current.
    http://www.dynojet.com/automotive_dyno/default.aspx
  18. Apr 9, 2013 at 10:10 AM
    #78
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Thank u sir
    So I need to find a guy named Eddie?
    Or avoid Eddie?
  19. Apr 9, 2013 at 10:14 AM
    #79
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Mustangs are eddie current, and require calibration of vehicle weight, gearing, tires and what not.
    An error by the dyno tester could make the readings incorrect. Anyone that uses it regularly can set up the parameters properly though. The PreRunner is already in the database as well. :thumbsup:
  20. Apr 9, 2013 at 4:04 PM
    #80
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Sonnnnuva................
