Dtc p2118 trying to repair
Discussion in '1st Gen. Tacomas (1995-2004)' started by snyper96799, Jan 29, 2013.
  1. Jan 29, 2013 at 5:25 PM
    snyper96799
    snyper96799 [OP] Well-Known Member
    Yon
    American Samoa
    03 Tacoma lifted
    6inch trailmaster, deckplate, custom halo lights, 18inch sub w/ 3000 watt amp, minor interior mods
    Hey everyone,im fairly new to TW i have been on here a couple times but just recently started an account. Anyways, i have a problem with my truck the battery leads were accidently put on backwards and blew a whole bunch of fuses. I managed to change them all but now the gas pedal goes about half way down before i can feel the butterfly in the throttle body engage. Ive scanned the truck and got DTC's P2118 and P0031. Ive researched the trouble codes and all i got was to change the ETSC fuse, ive done that but no fix. Ive also checked the connect to the throttle body and from the specs i got off of alldatapros it was in range. So i really don't know what else to check for. Our toyota dealer told me to buy a new throttle body which is +$1000 here on my island so i just wanna make sure that there are no other options out there before i buy it. Please any other suggestions on things i can check or a way to fix this would be appreciated
  2. Feb 10, 2022 at 8:44 PM
    Talon912
    Talon912 Member
    Hawaii
    Gonna restart this thread because im dealing with the same issue rn, any help pls
  3. Feb 10, 2022 at 9:18 PM
    tcjacado
    tcjacado Well-Known Member
  4. Feb 10, 2022 at 10:02 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    What is your problem?
    And what codes are you getting OP had 2 codes.
    1 for the ETCS circuit
    1 for the A/F Circuit
  5. Feb 11, 2022 at 10:15 AM
    Talon912
    Talon912 Member
    Hawaii
    getting
    PO560
    P2118
    problem is the butterfly in the TB isnt opening until throttle is pressed half way down (only opening 1/3 of 90° or so) fuses check out, just kinda praying i dont have to buy a whole new TB since my truck is a 03 and they dont sell sensors seperate, i read somewhere that it could be the MAF so gonna try to clean or replace
    and for the voltage code im clueless, brand new battery (truck just sits for the most part the battery was completely dead a few weeks ago) alternator is fairly new but havent gotten the chance to put a volt meter on it and check
