DTF 06 Brick Hecka House Build
Discussion in '2nd Gen. Builds (2005-2015)' started by DTFtacoma, Jun 5, 2012.
  1. Aug 20, 2012 at 9:16 PM
    #161
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
    You can run them either way, that is how your shackles and all tacomas stock are set up, the defined kit is the same way
  2. Aug 21, 2012 at 12:20 AM
    #162
    DTFtacoma
    DTFtacoma [OP] Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    :D
    yep
    Thank you
  3. Aug 21, 2012 at 12:32 AM
    #163
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    Cant wait to see the final result!
  4. Aug 21, 2012 at 6:22 PM
    #164
    santabarbarataco
    santabarbarataco Well-Known Member
    jordan
    santa barbara
    if the shackle was going down it would make the ride height higher than with it up, correct? what are other differences between the two different setups?
  5. Aug 21, 2012 at 6:35 PM
    #165
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Its more if your 1st or 2nd gen. 1st gen shackles hang down and the frame is straight in the back. 2nd gens are an inverted shackle on the side of the frame because the frame dovetails at the rear after the front spring hanger. You can can have hanging shackles on a 2nd gen but most stick with however it came stock. Ride height is not affected by one or the other, thats depends on the springs you have and how much rear weight you have.
    One difference is inverted shackles squat more when you hit the gas, traditional shackles hanging down actually want to raise the rear of the truck when you hit the gas
  6. Aug 21, 2012 at 6:56 PM
    #166
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    truth. Its crazy
  7. Aug 21, 2012 at 7:00 PM
    #167
    Cr250jumper
    The moon
    50 shades of tan©
    With weight in the bed it kinda cancels out, but yeah very crazy feeling not feeling it sag when hard on the gas from a stop. Aaron has a video of his bed empty and when he hits the gas it jumps up. From what I understand it helps the rear droop in between whoops when on the gas since leafs dont have a lot of rebound anyway
  8. Aug 21, 2012 at 7:22 PM
    #168
    santabarbarataco
    jordan
    santa barbara
    damn thats crazy! thanks for the explanation :thumbsup:
  9. Aug 21, 2012 at 7:29 PM
    #169
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    awesome!
  10. Aug 22, 2012 at 7:55 AM
    #170
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    It's very noticeable.
    Stopped/at idle:
    On the throttle:
  11. Aug 22, 2012 at 11:31 AM
    #171
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    When is this heep going to be done?!! :D
  12. Aug 22, 2012 at 11:34 AM
    #172
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    I feel that it will give me less side to side tacking on my rear end also. Did a brake job yesterday so didn't get much done on the taco. I did do this though
    EDIT: This is my sticker BTW it will only be the white part ^^^^
  13. Aug 22, 2012 at 11:34 AM
    #173
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    October :D
  14. Aug 22, 2012 at 11:35 AM
    #174
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    :woot:
  15. Aug 22, 2012 at 11:42 AM
    #175
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    DOWN TO FUUU.. oh wait....
    looking good man, just went through the whole thread...any chance you still have my stock uppers and lowers :laughing:
  16. Aug 22, 2012 at 11:44 AM
    #176
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    hahaaha yeah I still have em sorry about that just haven't been down there in a long time. I might be going to glamis in October so I could drop em off :cool:
  17. Aug 22, 2012 at 12:42 PM
    #177
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    will mine be done by then? :pout:
  18. Aug 22, 2012 at 12:57 PM
    #178
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    can you really ever say its done?
  19. Aug 22, 2012 at 1:22 PM
    #179
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    No so it will be drive-able by October :D
  20. Aug 22, 2012 at 1:23 PM
    #180
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Soon after
