DTLT and rear o2 sims
Discussion in 'Performance and Tuning' started by NtacomaR, Aug 9, 2012.
  1. Aug 9, 2012 at 7:51 PM
    NtacomaR
    NtacomaR [OP] Well-Known Member
    nick
    sparks
    2012 Tacoma Baja
    suspension, wheels, rims, trd exhuast, CAI
    will i pass smog with the rear o2 sims in place? im going to still keep my stock y-pipe and 2 cats. but i want to know if i go to do an emissions test, if i will pass or not?
  2. Aug 9, 2012 at 7:53 PM
    NtacomaR
    nick
    sparks
    2012 Tacoma Baja
    even if i keep 2 of the 4 cats. do they people know that they have 4 cats now a days?
  3. Aug 9, 2012 at 7:56 PM
    NtacomaR
    nick
    sparks
    2012 Tacoma Baja
    *IF* is they key. so im just basically taking a risk.
  4. Aug 9, 2012 at 7:59 PM
    NtacomaR
    nick
    sparks
    2012 Tacoma Baja
    shorties and a y pipe would pretty much be a risk too?
    ugh, so many decisions. just worried with shorties i wont feel enough of a gain...
    current mods, Airaid CAI, with TRD cat back
  5. Aug 9, 2012 at 8:03 PM
    NtacomaR
    nick
    sparks
    2012 Tacoma Baja
    well it had the exhaust on it already and i just installed the intake. minimal gains, but i did feel a slight more power. im looking to gain the most power but stay N/A
  6. Aug 9, 2012 at 8:06 PM
    NtacomaR
    nick
    sparks
    2012 Tacoma Baja
    lol yea, been doing a lot of youtube-ing. blowers are def bad ass. just pricey when in order to keep my warranty, i have to do it at the stealership
  7. Aug 9, 2012 at 8:13 PM
    NtacomaR
    nick
    sparks
    2012 Tacoma Baja
    i know that but its like close to $4,000. and i just bought this truck. dropping another 4k in it, gives me a blah side about it haha. but thanks for the info. i dont think ill mess with the cats then. (just read it gets LOUD if cats are removed) and i dont like rasp.
  8. Aug 9, 2012 at 10:42 PM
    2009tacomav6
    2009tacomav6 Well-Known Member
    phx AZ
    2012 4x4
    TRD SC TRD Cat Back KMC 17x9 Addicts
    I understand thr tubes also create a lot of extra heat. Were you going to spray them with a heat resistant coating?
  9. Aug 10, 2012 at 8:13 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You can always do like i did on my girl's truck. We installed JBA shorties. Had V-band flanges added to them, so that we could easily swap the cats out for "test pipes". It will cost you more, but will give you mkre flexibility as well.
  10. Aug 10, 2012 at 8:22 AM
    armyoffoo
    armyoffoo Scrotie McBoogerballs
    Houston, TX
    2018 Tundra CM TRD Sport
    Spraying them with coating or wrapping them will void your warranty with Doug Thorley.
  11. Aug 10, 2012 at 8:25 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    They are already coated from Doug Thorley themselves. Might not be the best ceramic coating, but still coated.
  12. Aug 12, 2012 at 4:24 PM
    aportis72
    aportis72 Well-Known Member
    Austin
    Supercharger
    or just live in a county that doesn't have emissions testing like me. I have a 2012 and im running DTLH URD 4x4 y-pipe, and URD/Magnaflow 3 inch exhaust. Waiting for aFe/TRD intake.
    Or just have your truck registered in one that doesn't have it. Easy as that.
