DTLT headers install problem?
Discussion in 'Performance and Tuning' started by kagmyster00, Oct 5, 2010.
  1. Oct 5, 2010 at 3:30 PM
    kagmyster00
    kagmyster00 [OP] Well-Known Member
    Mark
    05AccessOffroad
    Ok i got my headers today so i started to take off my stock exhaust manifold and as i got to the bolts that are on the brackets that go to the transmission where it connects to the Y pipe i ran into a problem i can not get these bolts loose i tried everything so im thinking about just cutting the bracket off would this be ok or do i need that support for the headers?
  2. Oct 5, 2010 at 5:35 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Try soaking with WD40, or PB blaster & use a breaker bar first
  3. Oct 6, 2010 at 7:45 AM
    kagmyster00
    Mark
    05AccessOffroad
    well i tried soaking it over night and spayed it again before i tried to get them loose well now the bolt is rounded off so now im screwed anything i could try without cutting it off
  4. Oct 6, 2010 at 10:36 AM
    Bobo_1
    Bobo_1 Well-Known Member
    Bobo
    Maryville, TN
    09 TRD Sport L-Bed
    I have no idea. I am doing mine this weekend. If there is a bracket there I wouldn't taking/cutting it off unless it is not used as part of the mount for the LT headers. I would going to Sears or any hardware/automotive store and getting the specific socket/tool used to get off rounded nuts. I have gotten round nuts off sometime by hammering on a smaller socket (real bitch to get it off), use a butane torch to heat it up, use a hammer and chisel to work it off. I have not looked at the nut so I am not sure if you could take a cutoff wheel to it to cut it away.
    BTW, anything you can share with me on doing this beyond your current issue - I started another thread asking for tips and suggestions. I don't have a manual and I assume there are no instructions in the box but I have done this on bikes and cars.
  5. Oct 6, 2010 at 10:40 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    i didnt remount mine and have had no problems
  6. Oct 6, 2010 at 4:15 PM
    roxspin72
    NC
    Oh Yeah!!!
    You can by a stripped nut or bolt remover. The size you need is 14mm
    Those brackets are there for a good reason. If the headers are not secured to the brackets, there could be issues with the motor tourqing and causing possible damage to the header flanges. Not 100% positive but I would hate to find ou the hard way.
  7. Oct 7, 2010 at 6:48 AM
    Bobo_1
    Bobo
    Maryville, TN
    09 TRD Sport L-Bed
    According to the install instructions I have both brackets are to be reused. Therefore, I wouldn't cut it! Keep them and reuse them. That is whay the end of the header is threaded to take the stock bolt.
