DTLT headers
Discussion in 'Performance and Tuning' started by grizzbear, Dec 5, 2011.
  1. Dec 5, 2011 at 7:32 PM
    grizzbear
    grizzbear [OP] Well-Known Member
    Are DTLT header really worth the money:confused: on a non s/c 4.0L
  2. Dec 5, 2011 at 8:08 PM
    grizzbear
    i heard that you lose power on the bottem end. but are they worth it in the long run?
  3. Dec 5, 2011 at 8:15 PM
    grizzbear
    Hmmm decisions decisions i low to mid range driving aswell
  4. Dec 5, 2011 at 8:20 PM
    Lucario Runner
    Lucario Runner Resident SUV racer
    Robert
    San Antonio, TX
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Shortie with test pipe then, or weld your cat on the shortie.
  5. Dec 6, 2011 at 1:10 PM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    Get an aftermarket ecu that allows you to be able to tune with E85. Leave all of your OEM exhaust components on. Then go get E85 inspected. That way you get a certificate and you no longer have to get emissions tests.
    Then put what ever free flowing exhaust on you want without having to worry about removing parts for an emissions test. Bam. Done. Any good aftermarket ecu can be tuned for just E85. You just make sure to have a separate tune for octane.
    ProEFI however can run both at the same time with a nice little sensor. :D Automatically adapts based on content.
  6. Dec 6, 2011 at 7:32 PM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    Nope. Just larger injectors most likely, due to the fact that running straight E85 requires about 30% more fuel.
    All injectors these days can handle E85. The fuel system components are built to as well.
    There are plenty of people that have the X-1 that have been running only E85 for quite some time now. Usually due to the fact that they want the extra power attained from the cooler burn of E85 for their s/c'd trucks. Still all applies though. Minus injectors the only other fuel mod those people have is the URD 255lph fuel pump kit.
  7. Dec 8, 2011 at 5:45 AM
    09Doright8126
    09Doright8126 Well-Known Member
    Andrew
    Greenwood, SC
    '09 DC TRD Offroad Pyrite Prerunner
    Aires chrome bullbar, Wet Okole seat covers, 6" KC offroad Slimlites w/ covers, upper Grillecraft black w/ TRD emblem, Redline hood struts, URD TCAI w/ black wrap, URD MAF Sensor, NST pulleys, NST intake manifold spacer, Bilstein 5100s, Eibach coils painted red, painted red brake calipers, SST brake lines, debadged tailgate, window tint, bed mat, extra D-rings, Rear TSB, Tranny TSB, swaybar removed, DTLT headers, URD Y-pipe, Vibrant Resonator, MagnaFlow
    I've got the DTLT headers + URD y-pipe w/ Magnaflow muffler on a non-supercharged 4.0. I haven't had the chance to Dyno but I would say that there is some loss in the low RPM range. Driving in town you can tell a difference and accelerating but once your going 55+ and/or cruising on the interstate power is certainly there.
    So, there are trade offs and if you ONLY drive around town and never drive your truck hard then I would say no they're not worth it. Would I install the same setup again? I'm 50/50.
