DTRL LED Mod ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by doubletaco, Aug 27, 2010.
  1. Aug 27, 2010 at 3:03 PM
    doubletaco
    doubletaco [OP] Well-Known Member
    Magnolia
    16 Quicksand TRD O/R 4x4
    TRD FJ Wheels, LED Fog lights
  2. Sep 17, 2011 at 10:40 AM
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    I sell a bulb called a switchback. This allows for white dtrl and turns amber when turn signal is activated. You are going have to buy resisters to slow the hyper flashing down. If you interested pm me and ill send you a quote with the leds and resisters. I also have all other leds both inside and out for all vehicles.
  3. Sep 17, 2011 at 10:53 AM
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    There is an electronic LED flasher that eliminates the need for those HOT resistors. I have one in my all LED truck.
    Some DTRLs have a pulsating voltage that ruins the LEDs. Just beware that they can go out for no reason.
    Also, buy really good LEDs with 3-chip SMDs or high power chips. Super bright LEDs are good, too. But just be careful. I have bought thousands of LED lights in the past and have had really good results with some and bad results with others. Some of the $50 bulbs actually have really excellent light output, but the 50/50 radial LEDs actually went out due to faulty resistors in them.
  4. Sep 17, 2011 at 11:38 AM
    csjumper2003
    Savannah, GA
    I know and the quality of leds I sell are excellent. Have had the ones on my truck over 2 years and supply a lit san diegans as well as other all over the US and a few in canada.
  5. Sep 17, 2011 at 1:20 PM
    csjumper2003
    Savannah, GA
    I understand flashers can be used but I haven't had Any problems with resisters. Your right though you can use flashers or resisters but they do the same thing just adds resistance. The flashers are a little more and try to keep the prices down for customers.
