DTRL Melting Lens
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Poacher, Oct 11, 2011.
  1. Oct 11, 2011 at 2:00 PM
    Poacher
    Poacher [OP] Well-Known Member
    Jim
    Northwest GA
    09 Crew Cab SR5 TRD 4x4 Tacoma
    Peragon Bed Cover
    Both my daytime running lights are melting the interior lens on my 09. Went to the dealer and they searched on the computer and found the issue, but said it is a 3 year/36K mile warranty--I have 40K on my rig. So they give me Toyota's 800 # and I just spent an hour with them to have them say that given my loyal customer status bullshit, they will pay for the parts and I can pay for the labor--on a reimbursment basis ($800+ total and they will pay me $589 back).
    That is not a bad deal, but they are stock bulbs and I have my Taco serviced at the dealer, so what happened to the 47 point inspection when they service my rig???
    I know you guys can help, so give it up before I explode
  2. Oct 11, 2011 at 2:10 PM
    saugus
    saugus Well-Known Member
    $800 for new headlights:eek:
    The daytime running lights melting is a known problem. You should lay into them for it to be free. Serious. It happens to every truck eventually.
  3. Oct 11, 2011 at 2:11 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    800?
    wtf?
    Go on ebay, get new assemblies for 70 bucks, install takes 15 minutes...
  4. Oct 11, 2011 at 2:19 PM
    Poacher
    Jim
    Northwest GA
    Peragon Bed Cover
    I was thinking my first response will be to just send me the new assemblies and I will install them myself. Then when they poo-poo that let them have it.
    Konaborne,
    I can't get ebay at work, so how much of the entire light set can I get? It is all one deal, is it not?
  5. Oct 11, 2011 at 2:22 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    You can buy the entire assembly for 70, and if you seal them up they should be fine. Doesn't take too long to put em in yourself either.
    Try make them pay for it though, since it is their problem.
    800?! Bah....that's horsebananas
  6. Oct 11, 2011 at 2:26 PM
    09taco4x4
    09taco4x4 Well-Known Member
    Louisiana
    09 DCLB TRD Sport 4x4
    Valant cold air intake kit Borla catback exhaust 6" Pro Comp Stage 1 Walker Evans 2.5's w/ TSB spring and add-a-leaf Light racing upper a-arms 285/70/R17 Dynapro ATM tires 17x9 XD wheels
    That's bull $hit they are being this firm about the mileage. I had the same problem that I didnt notice until around 45K miles and the delaership took care of it under warranty.
    They did also tell me that the headlights were $800 new!! (highway robbery)
  7. Oct 11, 2011 at 2:29 PM
    09taco4x4
    Louisiana
    Another option is to disassemble your current headlights and remove the inner lens that is cracked then you wont have that problem ever again.
  8. Oct 11, 2011 at 2:41 PM
    Poacher
    Jim
    Northwest GA
    Peragon Bed Cover
    I need to think about what to do, but it sucks that I have to fight them over it or do it myself.
  9. Oct 11, 2011 at 4:02 PM
    cverneau
    cverneau Well-Known Member
    Craig
    Cheshire, CT.
    11 Access Cab 4cyl 4x4 Auto
    AVS In-Channel Window Deflectors, AVS Rear Window Sun/Rain Deflector, EGR Front Hood Deflector, Weathertech Digital Fit Floor Liners With TRD Off Road Decals, TonnoPro Tri-Fold Cover, Coverking Black Neoprene Front Seat Covers & Front & Rear Center Console Covers, Black With Red Stitched TRD Head Rest Covers, Rear Grey Neoprene Wet Okole Seat Covers, Black Front Door Handle Pull Covers, Husky Custom Molded Mud Flaps, Devil Horns Of Fire On Satoshi, 7" Off Road Lights Mounted Behind Grill, Pop N Lock 5300, Seatbelt Chime Off, Interior & Exterior Led's, Cubby & Drink Holder Amber LED's, Infinity Reference #9633 6X9 Front Speakers, Solar-Gard HP Smoke 35% Tint, De-badged & Pinstripe Removal, Sun Visor Stickers Removed, Illuminated 4x4 Switch, ImMrYo Rear-View Mirror Lift Bracket, Ultragauge, TRD Aluminum Skid Plate, Bed Storage Cubby Locks Mod, Additional D-Rings In Bed, Rubber Bed Mat, Intermittent Wiper Stalk, Black Vinyl Arm Rest Mod, Secondary Air Filter Removal Mod, Spare Tire Rod Alignment Tube Mod, 14" Antenna Mod, Tailgate Theft Mod, DTRL Wire Jumper Mod, Parking Lights As Turn Signals Mod, Under Hood LED Strip Lighting Mod, 30 Watt Reverse Bulbs, PIAA 510's With LED's In Fog Locations, Cree LED Flood lights In Rear Bumper, Burner Bedlights In Bed Cubby's, Avid Light Bar, Horn Relocation Mod, Rear TSB Springs, Bilstein 5100's on all four corners - front set at 0.85", Cooper Discoverer ATP - 265-75R/16, Pioneer AVH-X3700BHS Head Unit With Microbypass, Added USB Charging Ports Under Dash.
    Last week I did the DTRL mod by jumping the wire from the side marker and utilising the "low" element of the bulb for the DTRL's. I've been reading avout the lens melting and bubbling problem for the last few days and decided to change the bulb to a lower wattage to be on the safe side. I stopped after work at Advance Auto and picked up a pair of 3057A bulbs for $6 total. I liked the spec's on the 3057 because the wattage was lower than the stock 4157 on both the "low" AND "high" element side.
    For reference:
    The 4157 is 28.5 / 7.5 watts
    The 3157 is 26.9 / 8.3 watts
    The 5702 is 26.9 / 8.3 watts (also a smaller bulb = further from the lens)
    The 3057 is 26.9 / 6.7 watts
    For people who have stock relays, any bulb will be better as you will utilize the "high" element for the DTRL's.
    For people who modified as I did, the 3057 is the better choice as it's the lowest wattage for the "low" element (the element used for the DTRL's)
    Also as a side note:
    When I replaced the bulbs this evening, I could hold the 3057 while it was lit in my hand without burning. The same cannot be said of the stock 4157, as it's VERY hot.
  10. Oct 11, 2011 at 4:05 PM
    dwalden2
    dwalden2 HBTFD
    Derick
    Blue Ridge, Georgia
    '05 TRD Offroad V6 6 spd
    SCS Stealth 6 Wheels, 285/70/17 STT Pros, Demello Offroad front bumper, 20" LED Bar, LED Fogs, LED interior lights, Wet Okole Seat Covers, Body Armour Rear Bumper, Smittybilt 10K winch, 3" OME Lift
    My mom's '05 Highlander did this a few years ago. Told Toyota about it and they didn't do crap. Said she could buy new lights and that was it. Stock bulbs. No idea why it happens.
  11. Oct 11, 2011 at 4:20 PM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    It seems to be an issues with very few as far as this board shows. If this happens to all Tacoma's with a little time, why have not all the owners of at least the '05 model complained? There are about 6 threads on this.. total.. you could find more posts on which floor mat to buy... doesn't sound like a major issue at Toyota. Shit happens, not need to blow it out of proportion.
    Frank
  12. Oct 12, 2011 at 1:31 PM
    Poacher
    Jim
    Northwest GA
    Peragon Bed Cover
    I called Toyota back and said I would pass on their offer and that since it is a known problem with a TSB and I have it serviced by their dealer, they should do something about it.
    I don't expect much.
  13. Oct 12, 2011 at 1:40 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The melting DTRL are not an eventuality for every Tacoma , DTRL has been mandatory on every Tacoma sold in Canada since the '05's and I haven't seen this as a prevelant issue here .
    It happens , but it's the exception not the rule .
  14. Oct 12, 2011 at 1:47 PM
    saugus
    o.k. I was just putting 2 and 2 together. If you shop on ebay, nearly every single used headlight has a melted drl.
  15. Oct 12, 2011 at 1:56 PM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    Im glad mine came with the DRL delete.....:D
  16. Oct 12, 2011 at 2:37 PM
    Highland Logan
    Frank
    Nova Scotia, Canada
    Really.. ? Find just 3 and post links.
    Frank
  17. Oct 12, 2011 at 4:20 PM
    saugus
  18. Oct 12, 2011 at 4:33 PM
    MrsPib
    MrsPib Well-Known Member
    Angie
    Texas
    TOYOTAS, TOYOTAS EVERYWHERE
    Hey, look, 9 assemblies that remind me of my hunks of junk.
    Toyota Dealership near me says bring it in, they'll call a manager to look at it and "go from there."
    Stay tuned....
  19. Oct 12, 2011 at 5:22 PM
    Highland Logan
    Frank
    Nova Scotia, Canada
    Boss? I'm just asking you to back up your "sky is falling" claims. Now not all of those links show or list damage. Between 2005 and 2011 (2nd Generation), Toyota Tacoma (US only) sales numbers are around 994 582. Just shy of 1 million sold in just the US. So how many lights would reasonably have to have issues before Toyota, or anyone (other than the effected) would think this was some type of serious systemic problem other than just their bad luck?
    Frank
  20. Oct 13, 2011 at 8:11 AM
    Poacher
    Jim
    Northwest GA
    Peragon Bed Cover
    Why does it matter how many are bad? If one of THEIR lights with THEIR bulbs are bad, THEY should replace them-period.
