DTRL Turn Signal Died
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Okeetee, Jul 20, 2013.
  1. Jul 20, 2013 at 9:32 PM
    Okeetee
    Okeetee [OP] I like the Anaheim Ducks
    Kyle
    Huntington Beach, CA
    '11 MGM TRD Sport DCSB 4x4
    OME 887 coil springs, Bilstein 5100s (front/rear), Light Racing UCAs, Wheeler's HD 1.5" AAL, 18x9 Pro Comp series 7032, Toyo Open Country A/T II (LT285/65R18)
    Hi all,
    Took the truck offroading this afternoon and came home to find my right front daytime running light bulb died. I have a 2011 Tacoma, no prior problems.
    Granted, my truck is COVERED in dust/dirt. Could it simply be a dirty connector/wire? Also, the turn signal clicks rapidly (the right rear blinker blinks rapidly -- front blinker still doesn't work). I tried searching for prior threads, but couldn't find anything of substance.
    Any help will be greatly appreciated.
  2. Jul 20, 2013 at 10:05 PM
    WHPLSH3
    WHPLSH3 Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    The DTRL and the signal light are the same bulb.
    I'd wager a guess that the off roading shook what life was left out of the filament. They have probably never been changed, no?
    If you need to do one, do both- the other side won't be far behind
  3. Jul 20, 2013 at 10:11 PM
    Germ
    Germ Master Navigator/Zipper Operator
    Arizona
    2013 TRD OR DCSB
    ^That. It's blinking rapidly to let you know you have a bulb out.
  4. Jul 20, 2013 at 10:12 PM
    Okeetee
    Kyle
    The bulbs have never been changed. Didn't think I needed to after only two years. :confused:
  5. Jul 20, 2013 at 10:18 PM
    WHPLSH3
    Vance
    Alberta
    The lifespan of these bulbs is shortened on our trucks because of the double duty they perform... more often than not, they're lit
