DTRL using both filaments 4157's
Discussion in 'Lighting' started by Icepuck72, Nov 22, 2011.
  1. Nov 30, 2011 at 4:02 PM
    Icepuck72
    Icepuck72 [OP] Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    Not a bad idea. Is your picture showing a DTRL socket or a non DTRL?
  2. Nov 30, 2011 at 4:14 PM
    Tacokevin
    Tacokevin Well-Known Member
    Kevin
    East Hartford, CT
    Kenwood Excelon DNX9960, Hertz speakers, Extang Trifecta Tonneau, 3" Toytec Bilstien 5100 coilovers, LR UCA, Diff Drop, Rear AAL Bilstien 5100's, XD Series Bully Wheels, 285/74R16 Nitto Terra Grapplers, Yellow fog lights w/ anytime mod to FJ oem switch, DTRL custom mod w/Switchback LED and stealth switch, Smoked Headlights, Wired Streamlight Rechargable LED flashlight, Color matched grill, Color matched power mirrors w/oem switch, Heated Murth Bicolor signal mirrors w/Highlander oem heater switch, URD short shifter
    they come with the same socket.....only difference between factory DTRL and no DTRL is a relay and a harness under the dash thats it
  3. Nov 30, 2011 at 4:30 PM
    Tacoma Mike
    Southern Maine
    Factory DTRL do NOT have both filaments on. Only high. By switching the wires you have made a dangerous mod. your parking lights are now bright and turn signals dim. Someone from the front will not be able to tell your turning.
    Do not do this and put them back the way they were. Use the low element for your parking lights. Then your brights are for turn and hazzard. If you want them bright then install a factory DTRL system.
    when someone plows into you you'll understand why.
  4. Nov 30, 2011 at 5:04 PM
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
    Not doing this....ordered an eight pin electronic flasher for my LED's and just not having DRL's. ;)
  5. Nov 30, 2011 at 5:09 PM
    Tacoma Mike
    Southern Maine
    :thumbsup:
  6. Nov 30, 2011 at 5:40 PM
    Tacoma Mike
    Southern Maine
    If your talking to me i just went out and reactivated my dtrl.
    Only one power input to the high side and no power to the low
    It definitely looks like both are lit but in my case they are not. the reflection wicked.
    took me a min before i could get the right angle (before i went blind LOL)
    So in my case it's no.........
    Or maybe i'm so tired i misunderstood the comment
