DTRL...who has it and how'd you do it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Veccster, Apr 9, 2009.
  1. Apr 9, 2009 at 1:05 PM
    Veccster
    Veccster [OP] bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    No much love over in the lighting forum but I know it's a popular mod. I am not sure which route to go to obtain daytime running lights.
    I followed 007's write-up and bought the relay and jumper for $50. I also read a write-up by PiercedTiger to do it for free.
    Each method has it's pro's and con's and most people will defend their method as the best. But please post how you did it and what you like/dislike about it.
    • When do they come on?
    • When do they turn off?
    • Are they bright (use both filaments)?
    • Are they on with/without your headlights?
    • Does it turn your taillights on as well?
    Also...did you install a switch to turn them off?
  2. Apr 9, 2009 at 1:06 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Check out the Mod and Tutorials link at the top of the page...
  3. Apr 9, 2009 at 1:06 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    scroll over the mods & tutorials button on top
  4. Apr 9, 2009 at 1:13 PM
    jonny
    jonny Betty White Edition Heep ZJ
    i bought the spade connectors from the dealership and tapped into the parking lights. they come on when i turn on the parking lights and turn off them i turn off the truck or turn them off. not bad for a $10 or so mod. i like them, but when i did my bhlm i took out the yellow reflector and painted the whole inner peice....so they aran't as bright as i'd like them to be. but still noticeable.
    few diff ways to do the mod
  5. Apr 9, 2009 at 1:16 PM
    Veccster
    Eric
    2020 Pro
    I didn't mean "HOW did you do it". I meant "how did YOU do it". There are two very different ways of doing it listed in that mod thread. There are several other ways posted on ToyotaNation.
    I would like to know how you did it and how you like it.
  6. Apr 9, 2009 at 1:20 PM
    Veccster
    Eric
    2020 Pro
    Don't the outer amber (parking) lights come on when you turn on the parking lights? What is the difference in how you did it?
    Why not just leave the parking lights on all the time? They turn off when you open the door, right?
    Pictures?
  7. Apr 9, 2009 at 1:21 PM
    Dark Knight
    Jeff
    NC/SC
    ok. the way i did it was run a pigtail wire from the parking light wire into the third, empty, connection on the turn signal/new to be DTDL connection and fill in the connector with silicone to keep the water out. I like this method because I works with the light switch and comes on with the parking lights. and I already had that little amount of wire lying around to do the mod. only took about 15-20 minutes to do.
  8. Apr 9, 2009 at 1:33 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    I did the 'free' DIY DTRLs. I also have the alternating turn signals going on (parking light/turn signal light).
    Being able to turn the running lights off was a key factor in why I chose the DIY DRTL mod vs the factor running lights. Although, I have noticed the factor DTRLs seem to be much brighter.
  9. Apr 9, 2009 at 1:41 PM
    Veccster
    Eric
    2020 Pro
    That is what I thought and is the reason I am leaning toward the relay with a switch. I want them to be as bright as possible. Dim lights look....dull :eek:
  10. Apr 9, 2009 at 1:56 PM
    Cooked Goose
    Cooked Goose Member
  11. Apr 9, 2009 at 2:05 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    I went with the flasher and relay from TRDparts4u.com also. Its a nicer install and seems safer rather then tapping into other wires.
  12. Apr 9, 2009 at 2:38 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
  13. Apr 9, 2009 at 2:53 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    I did it with factory parts (relay, etc.)
    When do they come on? Whenever the truck is on without the headlights.
    When do they turn off? Headlights on or truck is off
    Are they bright (use both filaments)? Yes -- very bright.
    Are they on with/without your headlights? They are on when the headlights are off.
    Does it turn your taillights on as well? No
    I contemplated a switch, but decided against it... I didn't see a reason to turn them off.
    :) I really like the way the truck looks with the DRLs on... :D
    ON:
    OFF:
  14. Apr 9, 2009 at 4:05 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    Mine was really easy. It came that way from the dealer.
  15. Apr 9, 2009 at 5:45 PM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    Buy the OEM parts, drive to my place, and I'll install it for you.
    Marc M
  16. Apr 9, 2009 at 9:08 PM
    Veccster
    Eric
    2020 Pro
    Hell of an offer...thanks! I already bought the oem relay and jumper. Before installing, I wanted to make sure I was doing it the way that seemed best to me.
    I'm sure it's not hard to do but I always like to have additional eyes when messing with something like my truck. I already lined up a friend to help but thanks again for the offer :thumbsup:
  17. Apr 10, 2009 at 6:59 AM
    jonny
    hey man
    yupp, the way i did the dtrl mod, the outer ambers come on as well. and i guess i could leave them on all the time being that they turn off then whe car is turned off and the door opens. :D as far as a pic, i dont have one but you should check out piercedtiger's set up
    http://www.tacomaworld.com/gallery/showphoto.php/photo/1811/cat/500
