Dual Batt. setup need help
Discussion in 'Technical Chat' started by Country, Mar 20, 2010.
  1. Mar 20, 2010 at 7:07 PM
    Country
    Country [OP] Well-Known Member
    Country
    East Texas
    2010 Dbl.-Everyone says it looks like a tank
    Pro Comp 6in lift w/ Icon Coilovers,AllPro UCA's, AllPro Baja Leaf pack, Bilstein 5150's in the rear. Tires Mickey Thompson MTZ 275/70R18 w/ procomp 7089 wheels. ARB front bumper with mile marker winch, Custom made all quarter inch steel rear bumper. Demello rock crusher slider's. CoverKing neoprene seat cover's, AllPro trail armor All-pro U-bolt flip kit with Timbren bump stops and many many many other mods, way to many to list.
    I am tring to find the wire to hook up the switch from the painless wiring dual batt. setup. I tied the wire into a pink wire but found out when I flipped to the switch it turned on the wiper blades. I need to find the ignition switch or something that will supply power to my switch harness without interfering with anything else on the truck, please help me out. pics would help out alot I am so illiterate when it comes to electrical stuff. Thanks fellas for the help
  2. Mar 20, 2010 at 11:09 PM
    Country
    Country
    East Texas
    anybody
  3. Mar 24, 2010 at 8:04 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I'm not sure what it is that your looking for. But I can tell you where the ignition wire is if that helps you.
  4. Mar 24, 2010 at 8:16 AM
    sethr21785
    sethr21785 Well-Known Member
    Seth
    Lake Jackson TX
    00 Tundra
    do you have a test light?? use it to find a wire that has power when you turn on the ignition..
  5. Mar 24, 2010 at 8:17 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    x2. If you're looking for a wire that becomes hot when the ignition is on, I can point you in the direction. I tapped into it to trip a relay to power an auxiliary fuse block I wired under the hood.
  6. Mar 24, 2010 at 12:55 PM
    Country
    Country
    East Texas
    tell me what wire u tapped into, what does it look like
  7. Mar 24, 2010 at 1:28 PM
    mjp2
    NJ
    It'll be a bit for me. The truck's at home and I'm not, but next time I'm there and have the hood open I'll break out the camera for you. :)
