Dual Batteries
Discussion in '1st Gen. Tacomas (1995-2004)' started by pelon, Feb 4, 2013.
  1. Feb 4, 2013 at 9:14 PM
    pelon
    pelon [OP] Well-Known Member
    Brian
    Westminster, ca.
    01 sloppy expo taco 4x4
    all-pro bumpers, skids & rock sliders, Smiity Built XRC 8000 winch, all-pro expo rack and leaves, Exit0customes dual swing rear bumber, cambrug mid-travel, manual lock conv, F&R 4.56's & ARB's, TRD sc, hdrs, exh, OMF bead locks, PCI radio, Tepui Roof top tent
    Just got done installing the Columbia Expoditions dual battery kit, with Odesseys and a T-max controller. Didn't quite work out as well I had thought. If you plan on using the1st gen Columbia Expoditions battery tray, note it does work with a TRD supercharger.
  2. Feb 4, 2013 at 10:08 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Got any pics of your setup?
  3. Feb 4, 2013 at 10:26 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    What didn't work out?
  4. Feb 4, 2013 at 10:44 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I am guessing but it could be the supercharger drive belt interferes with the coolant bottle. :notsure:
  5. Dec 11, 2013 at 7:37 AM
    tmreyes1
    tmreyes1 Well-Known Member
    T-Rey
    TX
    2017 TRD
    How are you liking the T-max controller? Will it allow you to use both batteries to jump start if needed?
