Dual battery first timer install advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by majesticmilo, Jul 6, 2024.
  1. Jul 6, 2024 at 5:55 PM
    majesticmilo
    majesticmilo [OP] New Member
    Thinking about adding a dual battery system in my 2013 dcsb with the sole purpose of powering a 12v fridge full time. Therefore, I wont include an inverter since I will only need the DC power for the fridge. And also my alternator is 130amp.
    Was going to go with a 12V 30amp Renogy DC/DC charger with MPPT so I can add solar later down the line.
    Im basing my numbers off this chart many of you have probably seen,
    http://assets.bluesea.com/files/resources/newsletter/images/DC_wire_selection_chartlg.jpg
    Im running wires from my engine bay back into the cab so I don’t think I will exceed 10ft there. Is there any incentive to use 4awg wire and say 90amp fuses for more safety? Or am I safe with what I currently have.
    Im trying to wrap my head around how to do this in a simple way and I’ve made this drawing to how I think I would do it.
    Please any input is welcomed.
  2. Jul 6, 2024 at 6:23 PM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Been along time since I wired in a dual battery but you should incorporate a battery isolater.
    BTW On the linked chart, What is meant by critical and non critical voltage drop?
  3. Jul 6, 2024 at 7:40 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    search "dual battery tacomaworld" on google, this has been covered extensively in great depth with tons of good setups over the past 20+ years.
  4. Jul 8, 2024 at 9:50 AM
    gstodd
    gstodd Well-Known Member
    2005 2wd base 5-lug
    For the length of your runs you should be fine with 6-ga wiring. absolutely do not put high than a 60A fuse on any of the lines. They specify 45-60A for a reason, it's to limit the amount of current able to go through the unit and the wires. Going with a higher amperage can cause problems.
    Since the battery is going to be used exclusively for the fridge get a deep cycle battery as it'll hold up to the repeated charge and drain cycles you'll be having.
  5. Jul 10, 2024 at 11:19 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    stock Alt can put out 130 amps max
    400 watts is like 33 amps at 14v.
    IxV=W
  6. Jul 10, 2024 at 11:42 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    @majesticmilo, I used 6awg welding wire with a 50A breaker under the hood and a second 50A slow burn fuse between the charge controller and house battery (I'm using the Renogy 50A mppt controller so size your fuses accordingly if the 30A controller has different requirements). You want the fuse/breakers to be the limiting factor, not the wire or charge controller. I like having a breaker because it's very easy to isolate the house battery and wiring from the rest of the vehicle.
    @1 Limited Toyota, the mppt is the isolator so there is no need to add one. The only time you'd need an isolator is if you are charging straight off the alternator with no charge controller.
    deanosaurus likes this.
