Dual battery for 15 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Coolcat, Nov 23, 2015.
  1. Nov 23, 2015 at 7:48 PM
    Coolcat
    Coolcat [OP] Member
    Colorado/Texas
    15 Tacoma 4x4 TRD Off Road
    Hello everyone,
    I'm in need of some guidance. I've been trying to get someone in Denver to help me install a dual battery system. Every time I talk to someone I get a different answer etc. I'm trying to set up my truck so that I can run an electric heater in my rooftop tent or a fan in the summer. I would like an isolator with a gauge but it isn't necessary if works the same
    I've had people offer to install the system in the bed of my truck, and every other place but I want everything under the hood.
    Thoughts...
  2. Nov 23, 2015 at 7:51 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Worst idea ever. Just don't do it.
    Seriously.
  3. Nov 23, 2015 at 7:56 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
  4. Nov 23, 2015 at 8:00 PM
    Coolcat
    Coolcat [OP] Member
    Colorado/Texas
    Why not do it? I just came back from SOuth Africa and everyone has a system to run dual batteries.
  5. Nov 23, 2015 at 8:02 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    How so?
    Coolcat[OP] likes this.
  6. Nov 23, 2015 at 8:02 PM
    Aguaski
    Aguaski Well-Known Member
    Clint
    2014 DCSB OR Prerunner
  7. Nov 23, 2015 at 8:13 PM
    Coolcat
    Coolcat [OP] Member
    Colorado/Texas
    Rocklobster, have you or anyone here used the armour kit you mentioned?
  8. Nov 23, 2015 at 8:14 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    First question, it's somewhat redundant, because it's still relevant to the following question I'm about to ask, but do either of you offroad?
    To everyone asking why, not to say you can't do it. I personally do not condone it. If you want to know why, go out to your vehicle and take a look at the top of the cross bar on your radiator support and attempt to twist it. You can do it barehanded.
    The sheetmetal for the radiator support is so cheap that it is constructed using near soda can metal. It can and will begin to collapse under the weight of the stock battery alone over time, which will also begin to slowly crack your radiator support bulkhead as well. Whether you offroad or not, it's actually fairly common even on street queen Tacoma's.
    Two 70+ lb batteries (if they are Optima) on top of the sheetmetal will almost guaranteed destroy your radiator support in much shorter order.
  9. Nov 23, 2015 at 8:37 PM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    Seen a dual battery set up in double cab behind the seat, thought that looked slick.
    12TRDTacoma likes this.
  10. Nov 23, 2015 at 8:43 PM
    kai38`
    kai38` Well-Known Member
  11. Nov 23, 2015 at 8:45 PM
    2big4arunner
    2big4arunner Well-Known Member
    Tyler
    Vernon BC
    2015 tacoma dclb
    3/2 leveling kit, 275/60r20 duratracs on xd128 20x9 rims, AFE stage 2 intake, trd exhaust, duel electric fan w/dakota digital controller
    You could always run two lithium batteries (look up ultralight batteries). Each one is around 1000 dollars but only weigh 6lbs each. they are also small enough that you could probably mount them elsewhere because they are smaller. consider a small lithium setup for the second unit since you will want to keep weight down and be able to drain much lower then a lead acid battery.
  12. Nov 23, 2015 at 8:48 PM
    ramonortiz55
    Ramon
    Texas
    stock
  13. Nov 23, 2015 at 8:49 PM
    2big4arunner
    Tyler
    Vernon BC
    2015 tacoma dclb
  14. Nov 23, 2015 at 8:51 PM
    docloco
    docloco Well-Known Member
    Ron
    Florida
    2015 MGM DCSB 4x4 TRD OR
  15. Nov 23, 2015 at 8:53 PM
    ramonortiz55
    Ramon
    Texas
    stock
  16. Nov 23, 2015 at 8:55 PM
    kai38`
  17. Nov 23, 2015 at 9:29 PM
    2big4arunner
    Tyler
    Vernon BC
    2015 tacoma dclb
    ????? Yes?
  18. Nov 23, 2015 at 9:29 PM
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    What kind of help do you need? I'm running dual batteries under the hood and slowly developing a mount for OR models.
    Dude what happened?!
  19. Nov 23, 2015 at 9:30 PM
    ramonortiz55
    Ramon
    Texas
    stock
    That mini battery thing is LEGIT..
  20. Nov 23, 2015 at 9:35 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Didn't you see my radiator support? It's thrashed just off the weight of the stock battery alone. Granted I offroad and pretty hard at that, but nevertheless this can and will happen even if you drive on the street. It will take longer but I digress. The point is, dual batteries in the stock location or even anywhere on the fenderwell if relocated, seperated, etc, will crack, tear, collapse the stock sheetmetal in the front end without a doubt. The problem is amplified if you run Optima's since they are so dang heavy.
