Dual battery for 15 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Coolcat, Nov 23, 2015.
  1. Nov 23, 2015 at 10:42 PM
    #41
    2big4arunner
    2big4arunner Well-Known Member
    Tyler
    Vernon BC
    2015 tacoma dclb
    3/2 leveling kit, 275/60r20 duratracs on xd128 20x9 rims, AFE stage 2 intake, trd exhaust, duel electric fan w/dakota digital controller
    just wondering... has anyone tried to make a mount setup that runs off the frame to help support this weight?
  2. Nov 23, 2015 at 10:45 PM
    #42
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Still disagree. There are plenty of 05's running around with rusty frames and dual battery setups doing just fine and have seen some gnarly shit i'm sure. The point I'm making is, unless you are bashing on the truck, its gonna be fine. Hard hits are what makes shit break. Offroading isn't going to break stuff if done responsibly.
  3. Nov 23, 2015 at 10:46 PM
    #43
    VolcomTacoma
    Jeff
    NorCal
    I've thought about that as well, I dont see why you couldn't, however the support would probably be barely stronger than the inner fender since you cant gusset the support without going in to the fender well and possibly impeding tire travel
  4. Nov 23, 2015 at 10:52 PM
    #44
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Based on what I have been told by various body shop workers, a cracking radiator support is overwhelmingly common on Tacoma's.
    Before you say that it happened because of the accident they are in for, the hit occured in area's not even close to the front end sheetmetal.
    Disagree with your disagree.
  5. Nov 24, 2015 at 2:46 AM
    #45
    Coolcat
    Coolcat [OP] Member
    Colorado/Texas
    15 Tacoma 4x4 TRD Off Road
    I was talking about the physical mount. I am looking at putting the two batteries in the space of the original battery with an adaptor kit like the one mentioned by armortechoffroad.
    As far as batteries go I asked my local mechanic about Optima and he told me that they are constantly replacing them because of the cold in Colorado. I live in a ski town in the winter and they tell me that they don't do well at altitude. Some of their clients are guys using plows etc but I don't want to end up getting a battery I have to replace every year.
  6. Nov 24, 2015 at 3:57 AM
    #46
    ddog45
    ddog45 Well-Known Member
    Darin
    Longmont Co
    2014 double cab trd offroad
    I have a dual battery tray from columbia overland that I modified a bit to run 2 group 31 batteries it is all controlled by an IBS dual battery system. If anyone would like to pm me for pictures and info Im happy to help any way that I can. I feel like a dual battery setup should be the first mod that should be done.
  7. Nov 24, 2015 at 4:58 AM
    #47
    Coolcat
    Coolcat [OP] Member
    Colorado/Texas
    I would like to see that setup.
    I do not have the tools or the skills to do the work myself, (YET) so is there a shop that you recommend in Denver or in the mountains? I live near Aspen.
  8. Nov 24, 2015 at 7:58 AM
    #48
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    I've had good luck with mine. I don't live in such cold conditions as you, but I cycle mine all the time. On a normal outing camping or one winch pull would kill a normal battery.
    Optimas have a good warranty and my first one lasted 5 years until I hit it with a hammer.
    The only thing I would advise against two batteries in the stock location, and what lead me to develop mine, has a little to do with what @12TRDTacoma mentioned. Two batteries, especially two 31 group batteries, weigh a lot. If you ever pull out your battery and take off that plastic liner on the bottom, there isn't much there to hold the batteries.
    I don't have anything against that kit, nor an experience with it, but in my opinion that is too much weight on that one corner of the truck.
  9. Nov 24, 2015 at 8:03 AM
    #49
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    why did you hit it with a hammer? :confused:
  10. Nov 24, 2015 at 8:08 AM
    #50
    Iggy
    Northern CA
    Check out the build
    I was trying to get a new terminal on and I was tapping it to get it to seat. Bad idea. A really expensive mistake. I think something inside the battery got disconnected.
  11. Nov 24, 2015 at 8:10 AM
    #51
    ramonortiz55
    Ramon
    Texas
    stock
    i have to admit ive done the same.. but never hurt the battery..
  12. Nov 24, 2015 at 8:26 AM
    #52
    LiveFreeOrDie2015
    LiveFreeOrDie2015 Well-Known Member
    York PA
    15 DCSB TRD OFFROAD
    3in lift,Fox suspension,chaos UCA,AAL,leer 180 topper,SilverStar zXe headlights & fog lights,BAMF kickout sliders,Mobtown full skids,Pelfreybuilt center hoop, Pelfreybuilt Gas Tank Skid,50" curved LED light bar, Hood scoop LED, Tran cooler and fan,Oil Catch can,LED Strip lights under hood & Bed,
    With a 2015 you need to move emissions pump and remount power steering reservoir over about 1 in.
  13. Nov 24, 2015 at 8:27 AM
    #53
    ramonortiz55
    Ramon
    Texas
    stock
    there you are.. youve been too quiet..
  14. Nov 24, 2015 at 8:31 AM
    #54
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
    I've bin surf fishing all week haven't Check in much
  15. Nov 24, 2015 at 8:32 AM
    #55
    ramonortiz55
    Ramon
    Texas
    stock
    how's that coming along?
  16. Nov 24, 2015 at 8:33 AM
    #56
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
    Very slow only got one 26 in striper........need to be 28 and up
  17. Nov 24, 2015 at 10:07 AM
    #57
    Yukon Yak
    Yukon Yak Well-Known Member
    Denis
    Whitehorse, Yukon Canada
    2015 TRD Access Cab Trails Team
    BFG KO2 285/75R16 OME 886/Dakars Rotopax Pelfreybilt Aluminum Front/Rear HC with gate Dual Batteries Rigid fogs, 20 inch spot/flood, SQR back up Cobra 75, 3' fire stick Custom Storage/Dog Platform in Cab Allpro Apex sliders Allpro Apex Aluminium Pack Rack Allpro Aluminium Gear Rack
    I like the passenger side location for the aux, would I be correct in assuming that I can still add a snorkel if I place the second battery there?
  18. Nov 24, 2015 at 10:10 AM
    #58
    Iggy
    Northern CA
    Check out the build
    I believe so! I think a snorkel adapts to the factory intake. We'll find out soon though as I am getting a snorkel my self.
    LiveFreeOrDie2015 likes this.
  19. Nov 24, 2015 at 10:19 AM
    #59
    Yukon Yak
    Denis
    Nice, the snorkel was the next upgrade, but a friend decided to buy the wife and I an ARB fridge so I am accelerating the Dual battery install. My next mod day/days has become quite intimidating.
    AUX Batteries, IBS monitoring Bussman Fuse panel, your switch panel, Pelfrey bumpers front and back, rigid lights, winch, 886 coils - every is just piling up in a room in my house. Once the bumpers arrive I'll have my work cut out for me.
    Trying to figure out the wiring and future wiring requirements at this point as I'll have the truck dismantled.
  20. Nov 24, 2015 at 10:33 AM
    #60
    kai38`
    kai38` Well-Known Member
    I was able to install a snorkel after the 2nd battery was installed.
