Dual Battery Fuse/Breaker Layout
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RedZeppelin, Jan 28, 2020.
  1. Jan 28, 2020 at 7:17 PM
    RedZeppelin
    RedZeppelin [OP] Well-Known Member
    So I'm in progress on doing electrical work and wanted to get a sanity check. Here's what I'm planning to do when everything is said and done, please don't judge me this took roughly 200 hours in MS Paint:
    The green boxes are circuit breakers and brown are MRBF terminal fuses. I'm not sure entirely about the orientation of the breakers. Since I'm planning on using the SBI-12D isolator the current can flow both ways, and therefore I'm guessing that the position of the breaker studs are important. For this breaker https://www.amazon.com/dp/B01G2JMEUQ there is an AUX side and a BATT side. Would it be correct to have the AUX side wired to the battery terminal, and the BATT side wired to the isolator?
    And it would follow that a 150A breaker for the SP 9100 would have the AUX side wired to the SP positive post and the BATT side wired directly to the house battery positive terminal.
    Finally, can I have all the negative leads attached to the negative bus and then have one wire going to the negative post of the main battery? Or is it better to have separate leads for the various components?
    Thanks all
  2. Jan 28, 2020 at 7:23 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Yes isolators should be in the correct orientation.
    I don’t know your loads so can’t comment on the sizing.
    Be sure to add up all your loads to calculate the size of the negative.
  3. Jan 29, 2020 at 7:02 AM
    caribe makaira
    Caribbean, Puerto Rico
    You are missing the generator power input...in the drawing.
    Also:
    Why do you have an additional isolator?
  4. Jan 29, 2020 at 11:51 AM
    RedZeppelin
    The alternator is part of this, I just didn't include a direct connection in the diagram. The SBI-12D is for a manual override to link the two batteries together in case of a dead starter.
  5. Jan 29, 2020 at 11:59 AM
    caribe makaira
    SP 9100 breaker should be lower:
  6. Jan 29, 2020 at 12:11 PM
    RedZeppelin
    I've also seen that the SP 9100 has internal MOSFET protections so it might not even need a breaker. I'd even be fine carrying a spare 125A fuse for the power cable
