Dual battery/isolator/aux fuse box question...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hammertaco11, Mar 9, 2018.
  1. Mar 9, 2018 at 4:50 PM
    hammertaco11
    hammertaco11 [OP] Well-Known Member
    East Bay, Ca
    2014 Tacoma SR5 Pyrite Mica
    OME lift w/ HD Dakars Pro Comp 17" 7069 BFG KO2 275/70
    So I thought I had a clever way to make this work, but I seem to have caught a snag...
    My initial plan was to run an auxiliary battery off of my starting battery, with a dual battery isolator relay. Pretty much got that working. The next part is where my snag comes in...
    I wanted to run the aux fuse panel off of the auxiliary battery, but instead of the direct current causing it to be 'always on' even when the car is off, I wanted it to trigger on when the car is on. So I ran another battery relay isolator from the aux battery to the aux panel, that is triggered to the 30a fuse for the radio in my main fuse panel to turn on when the car is on. The thing is, when this is all set up, and I test my aux panel, it still has constant power even when the car is off.
    What am I doing wrong? Is the second isolator too redundant/messing things up? Is there another way to trigger the aux fuse panel to come on when the car is on?
    Sorry if my explanation of things isn't clear, let me know if I need to add more detail to help explain better. Any help is appreciated. Thank you
    GREENBIRD56 likes this.
  2. Mar 9, 2018 at 4:56 PM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    My uneducated thoughts, You need to run the relay before the aux battery, as the aux battery is always on.
    PzTank likes this.
  3. Mar 9, 2018 at 5:05 PM
    hammertaco11
    East Bay, Ca
    Well, I have 2 isolator relays, one between the dual batteries, and the next between the aux battery and the aux panel. My thought was that the second relay would be used to trigger on the aux panel at start up. The aux battery is always on, which in my mind, if I didnt have the second relay, would make the aux panel always on.
  4. Mar 9, 2018 at 5:07 PM
    hammertaco11
    East Bay, Ca
    my schematic is like this:
    Main Battery -> Isolator relay -> Aux battery
    Aux battery -> isolator relay -> aux panel
  5. Mar 9, 2018 at 5:35 PM
    Spare Parts
    Southern Maine
    K, didn't pick up on the first relay.
    hammertaco11[OP] likes this.
  6. Mar 10, 2018 at 4:07 AM
    Spare Parts
    Southern Maine
    I woke up thinking about this.
    1-not sure a relay is the right thing to use. First, does the relay allow some energy to pass through and then when switched on, allows more juice to flow. Or does it only allow energy to flow when switched on? I think I have seen folks using a solenoid to control the flow.
    2-I'm don't believe you need both relays. I would remove the one between aux bat and aux fuse box.
  7. Mar 10, 2018 at 4:42 AM
    Spare Parts
    Southern Maine
    Also, dont you need to tap into an ignition feed wire for your relay?
  8. Mar 10, 2018 at 7:34 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    If you're only feeding the aux fuse panel with 30 amps, you can use a bosch relay. Using terminals 87 and 30 to switch the power to the aux fuse panel. Wire the feed from the battery with a fuse, to terminal 87. Terminal 30 connects to the fuse panel feed. If you reverse these 2 terminals then terminal 87a becomes hot when the relay is turned off. Terminals 85 and 86 are the coil that turns on the relay. Ground one and use a switched 12v on the other to turn the relay on with the key.
    Spare Parts likes this.
  9. Mar 10, 2018 at 7:57 AM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    this is how i have my acr set up, i have a ignition isolator running to the acr so it delays it to the house battery and its accessories
  10. Mar 10, 2018 at 11:24 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    You initial set up should have worked - using an ignition-on component to trigger the isolator. Maybe, you connected the wire to the wrong side of the fuse? Disconnect the wire and see if power to the isolator is disrupted. Use a voltmeter to make sure there is no power at your connect point when the power is off.
    What isolator are you using? Most use power to close the points, allowing power to run through; some are the other way around, using power to open the points; thus, power goes through when no power is applied to the isolator.
    hammertaco11[OP] and Spare Parts like this.
  11. Mar 10, 2018 at 7:14 PM
    hammertaco11
    East Bay, Ca
    if I were to remove the relay between the aux battery and fuse box, then the fuse box would always be on, which is kinda what i'm trying to avoid. I'm definitely gonna look in to the solenoid option
  12. Mar 10, 2018 at 7:18 PM
    hammertaco11
    East Bay, Ca
    I think you're right, i'm gonna have to do more testing to see if the wires on the isolator are set up correctly. I'm using this iso in between my aux batt and aux fuse box:
    https://www.amazon.com/gp/product/B001HC6UJ0/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    this is my aux battery:
    https://www.amazon.com/gp/product/B00IUWLZMW/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    the isolator didnt come with instructions on which wire to hook up to and where, and I guess i just figured like my initial and larger isolator between the cranking battery and aux battery, on which the instructions noted that the hook up between the trigger and the ground didnt really matter. I'll have to do some more testing on this. Thanks to you all for the input, I really appreciate it
  13. Mar 10, 2018 at 7:28 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Not that its creating your problem, but that battery is NOT what you want to use for an aux... you need to find a deep cycle battery.
    If you want to find a small battery for aux you might look into wheelchair batteries.
    PzTank likes this.
  14. Mar 10, 2018 at 9:56 PM
    hammertaco11
    East Bay, Ca
    Really? Is this one considered a cranking battery? will this one damage my components?
  15. Mar 10, 2018 at 9:58 PM
    excorcist
    Reno, NV
    Won't damage anything, you're battery just isn't designed to be drained and recharged like you have it set up.
  16. Mar 11, 2018 at 6:39 AM
    Spare Parts
    Southern Maine
    I was thinking that if you weren't supplying juice to aux battery, it wouldn't supply juice to aux fuse box. I seemed to forget that the aux battery will still hold juice. :facepalm:
  17. Mar 11, 2018 at 12:53 PM
    Chuy
    Lakeside, CA
    Silver Taco
    @hammertaco11 That solenoid should be fine. It doesn't matter which of the smaller connections go to the ground source. Your issue is going to be with the wiring. I think you tapped into a live wire.
    I have a similar setup, using a second solenoid to run juice to a fuse panel. However, my setup is all manual; I'm using a DPDT switch to manage both solenoids. But, I have thought about running the second solenoid to an ignition-on source. Using a voltmeter I found an available connection in the fuse box. Some day, when I run out of projects, I may re-wire it.
  18. Mar 11, 2018 at 2:11 PM
    excorcist
    Reno, NV
    Interesting, I do not at all profess to be an expert in this stuff - in fact quite the opposite. I would be very interested to hear where you gathered the info about gel batteries having deep cycle capabilities (no sarcasm) .
    My career for the last 8 or so years has been building custom motorcycles and I can only speak from what I have observed, these little batteries DO NOT like to be discharged over and over, it kills them very quickly. Be it AGM, Li-ion, or standard lead acid. While the former might have a little more resilience than a standard lead acid, they still seem to hate a discharge of more than 70% or so repeatedly..
    Again I really have no science based info to back this up personally, just purely observational.
    Edit: out of curiosity just went and looked at one of the li-ion batteries pamphlet and it clearly says not to allow it to discharge on the front. All the AGM batteries I have had say the same
    Another Edit: reading the page on his battery I came across this so I dont know maybe he will be fine:confused: Saying it can be re-charged that many times kind of alludes to the fact that it can be dis-charged that many times.
  19. Mar 11, 2018 at 10:44 PM
    Chuy
    Lakeside, CA
    Silver Taco
    Sir, you correct. I was thinking AGM. I have a Deka Intimidator which is not designed for complete discharging but can recuperate better than a standard battery from a discharged state. I edited my entry; thanks for correcting me.
