Dual Battery kit - Off Grid Engineering - Battery Doctor
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by patchesj, Oct 29, 2021.
  1. Oct 29, 2021 at 2:48 PM
    patchesj
    patchesj [OP] Well-Known Member
    -----SOLD------
    I pulled my HAM radio and gear, no longer have a need for this kit. This is everything you need except for a battery (I have one, but will not ship. Contact me directly if you are in the KY area for discussion).
    Asking $400 shipped. I have this out of the truck, boxed and ready to get to UPS the day after payment received. Prefer paypal.
    Off Grid Engineering Aluminum 2nd battery holder. This goes over on the passenger side, requires an ATRAC equipped Tacoma. "CNC machined from 6000 series aluminum and precision TIG welded, this battery tray is designed to fit the 2nd and 3rd Generation Toyota Tacoma equipped with ATRAC (TRD Off-Road) and allow fitment of a second battery in the engine compartment.This tray WILL NOT fit TRD Sport model or SR5 model Tacomas. This tray will also NOT FIT SOME 2005-2006 TRD OFF-ROAD MODELS. Please check your truck for an ABS distribution block that may reside on the passenger fender near the firewall. It is a block with several brake lines protruding from it. "
    This is the link to the battery tray:
    https://www.**************/collections/battery-trays/products/toyota-tacoma-auxilary-battery-tray
    All wiring is 4 gauge with crimped lugs and connectors as well as battery terminals with multiple 4/8/12 gauge holes for connecting your secondary loads or distribution blocks. Dual fuse holders with fuses.
    WirthCo Battery Doctor 150A isolator/auto relay with manual override. This automatically connects the batteries and charges the secondary battery while the engine is running, disconnects when not. Push a button to connect and jump start if your main battery goes dead.
    This setup should take under an hour to get installed.
    LUNCHB0X66 likes this.
  2. Nov 7, 2021 at 11:31 PM
    LUNCHB0X66
    LUNCHB0X66 Well-Known Member
    Eric
    2012 Tacoma Prerunner
    None
    Link is bad, how much did you get the tray for? I have everything but a tray
  3. Nov 8, 2021 at 2:56 AM
    patchesj
  4. Nov 8, 2021 at 7:10 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Tacomaworld blocks some websites. I don't know much about this but looks like Offgrid Engineering is one of those sites. The OP won't be able to provide a link as it'll be automatically killed by the forum. Just google the product, it's easy to find.
  5. Nov 8, 2021 at 10:45 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    @patchesj Have any pictures installed in the truck? Also, any reason why you didnt go with the OGE Redarc or Blue Sea Isolator/Relay? Have been piecing things together and was going to order the full OGE+Redarc Kit. But between wait times and cost.. I may be just fine ditching the Redarc for this setup.. IF it would work that is..
    @BEAR_KNIFE_FIGHT any insight on this setup my man?
  6. Nov 11, 2021 at 6:46 AM
    patchesj
    I pulled it from the truck already, let me look for some old pictures. The battery doctor kit did everything I needed, wasn't looking for in cab controls. Figured if I needed to jump the car, the hood is going to be open and I can just push the button...
  7. Nov 13, 2021 at 11:07 AM
    RipcurlUSC
    RipcurlUSC Well-Known Member
    Jesse
    SoCal
    2006 DCSB 4.0 4X4 Black
    Stuff here and there. Built not Bought. Fabbing w/o Fibbing
    Is it true that this only works on lead cell batteries and not agm?
  8. Nov 13, 2021 at 12:17 PM
    patchesj
    I don't know why it wouldn't work with AGM. It senses the voltage when the engine is running and closes the circuit to the 2nd battery. When the engine stops (alternator not charging) it disconnects the feed to the 2nd battery. The loads remain connected.
    If the alternator works with AGM, there shouldn't be any difference.
  9. Nov 13, 2021 at 12:21 PM
    patchesj
    I don't see any real benefit to the Redarc, unless you are planning on using solar panels. Otherwise, it's just a latching relay.
  10. Nov 13, 2021 at 12:23 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I am actually.
  11. Nov 15, 2021 at 10:38 AM
    patchesj
    Price reduced to $400. :eek:
  12. Nov 27, 2021 at 6:54 AM
    patchesj
  13. Nov 28, 2021 at 7:22 AM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    Between not having solar, I'd also say that it's just a "dumb" battery isolator -- it doesn't do DC/DC charging beyond equalizing the voltages in the batteries. The Redarc is a DC/DC charger and also is a bit more intelligent when it comes to charging profiles for different chemistry batteries. I'd personally prefer a DC/DC charger over just a battery isolator, but people have different needs/desires.
    Sorry about the delay man!
    REDARC_Ryan and XPOTRPR[QUOTED] like this.
  14. Nov 28, 2021 at 4:22 PM
    patchesj
