Dual Battery system or not?
Discussion in 'Technical Chat' started by sierrahsky, Sep 16, 2010.
  1. Sep 16, 2010 at 11:11 AM
    sierrahsky
    sierrahsky [OP] Expedition Style
    Hi Guys,
    I am building up my tacoma so I can stay out in the snow and cold for longer periods of time without having to worry about the truck. I am looking to upgrade my battery because I am using the outlet more than I expected and also am going in to the cold temps way more. What should I do? The dealership has recommended I just get a better battery and that would be fine, a few other guys suggested a dual battery system? Not really sure what route to go and was hoping to get some solid answers as I always have in the past on TW.
    BTW I am running an on board air compressor , pumping up air mattress, charging radio's, lighting systems, and running stereo when in camp. I have already drained my battery once and was stuck out in the snow.... sucked... but what do I do?
    Dual Battery?
    Better Battery?
    Leave it alone?
  2. Sep 16, 2010 at 2:52 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    An excellent question, one I've been pondering as well. In addition to the items you mentioned, I am thinking of installing a winch.
    I have heard that it is not good to drain a "starting" battery too many times. It will eventually take it's toll on the battery. It would seem that having a dual bat system where the 2nd bat is a deep cycle type would be a better option for these things.
    Very curious to see what others have to suggest.
  3. Sep 16, 2010 at 3:09 PM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
  4. Sep 16, 2010 at 4:01 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Starting battery drained three or more times=dead. Use a deep cycle battery as a secondary battery and an isolator rated at the output of your alternator. You'll need to reroute power from the deep cycle to the accessories you want to run, or use a battery A/B select switch. The selector switch will allow you to run the truck off of one battery or both.
    In summary: isolator allows charging of both batteries, but keeps each battery on it's own circuit. The switch allows you to switch between using either battery to power the truck.
    Hope this helps.
  5. Sep 16, 2010 at 4:27 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Something to consider is the Die Hard platinum battery. Supposedly they are made by Odyssey and are really good batteries.
    Also have you looked into portable battery packs like this duracell one?
    http://www.kmart.com/shc/s/p_10151_...002543630000P&aff=Y&sid=KAx20061023x272xTier3
    I got this one off ebay for around $60 new. It will run a 13 inch tube tv for over an hour according to the status thing.
    It also came with jumper cables but I have yet to test them.
  6. Sep 16, 2010 at 8:17 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Wow, just did a google search for 'battery isolators'. There is a lot of choices/options to sort out. For instance, the output amps of a stock alternator play a factor in choosing the correct isolator. One of the things I've read about winching is, a higher amp alt may be necessary.
    Any thoughts on brands and amperage capacities for a 2 bat isolator?
  7. Sep 16, 2010 at 9:28 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    If you plan on ever upgrading your alternator, get the isolator that can handle the amps.
  8. Sep 16, 2010 at 9:35 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    I would do a dual battery and when you go out bring an extra battery, in the cab incase you drain both, to start the truck.
  9. Sep 17, 2010 at 10:03 AM
    sierrahsky
    After getting stuck out there I started bringing a "jump me" battery system I got from costco, but I hate to even have to worry that much. The dual battery system sounds kind of overkill being that I am not running a winch, unless I am not understanding it properly. Forgive me as I am new to electrical systems and so on but how does a deep cycle battery differ from the tacoma battery? If my main concern is cold coupled with extra use, a member suggested a red top optimum? Does any one know a place that have a diy dual battery set up that is not junk? I only felt its overkill because my local shop wants an arm leg and shoulder to install !!
  10. Sep 17, 2010 at 10:09 AM
    Chris D.
    Chris D. Well-Known Member
    Eagan, Minnesota
    2002 Tacoma RZN150 turbo
    2RZ-FE Turbo Intercooled, standalone........... Exactly 150% more power to the wheels than stock at the wheels. Supra transmission, 4 linked rear, QA1 coilovers all around, S-Runner rear sway bar, Corbeau bucket seats, forged 5 spoke 17x9 wheels, Wilwood 12.19" 4 piston brakes, Ford 9" rear end (early bronco) 31 spline, full floater, big bearing, 3.50 gears, trac-lock. fully functioning air conditioning and cruise control....
    gas generator.. ;)
    or get one of those setups that cuts power off to everything else when it falls below a certain voltage so ou'll have enough power to start the truck..
    how cold is cold, where is this cold location?
    red tops HATE to sit around without being used..
    a blue or yellow top likes to dip low after sitting for a while and still be able to start..
    I's look into doing the "Big 3" wiring upgrade under the hood.. it helps the charging system..
  11. Sep 17, 2010 at 10:30 AM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    The "Big 3" or whatever will not make a difference here. The issue is cold weather affecting the battery.
  12. Sep 17, 2010 at 11:21 AM
    sierrahsky
    Cold is under the car, around the car and coming down from the sky, usually snowing or in snow up to 3 feet deep, starting truck at 4 am usually between 0 - 30 degrees depending.
  13. Sep 17, 2010 at 2:06 PM
    Tim A
    Tim A Well-Known Member
    Montana
    2011 TRD Offroad 6 spd Double Cab
    It'll be expensive to do it right but if you're spending many consecutive days in the "bush" then check out the national luna DIY kit. Comes with everything you need except the second battery. I don't need anything like this but I'd love to have it in case the zombies attack.
    http://www.sierraexpeditions.com/index.php?l=product_detail&p=543
  14. Sep 17, 2010 at 2:11 PM
    Chris D.
    Eagan, Minnesota
    If the battery isn't seeing an effective charge, it won't hold a charge as long while sitting,
    the big 3 should definitely be on the list while your in there anyways..
    My truck has always turned over in -40 weather with a wind chill..
    Before I did the big 3, it was a little sluggish on the start up..
    With no other mods other than the big 3 upgrade, it greatly increased my charging voltage to where I see consistantly about 14.1 - 14.3v while running.. sitting for the same amount of time I noticed on my ScanguageII I had more voltage ready to go in the on but not running position.
    I'm not saying it'll cure all of his issues,
    but if you can make a system more effecient,
    why not while your in there?
