Dual battery system
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cornfed99, Jul 1, 2016.
  1. Jul 1, 2016 at 3:20 AM
    Cornfed99
    Cornfed99 [OP] Member
    Jacob
    Iowa
    99 SR5
    Anyone who runs a dual battery system, advice please. What isolator do you use, and where did you place the battery?
  2. Jul 1, 2016 at 3:33 AM
    supermike
    supermike Well-Known Member
    Columbia Overland Dual Battery Trays
    Blue Sea Systems ML-ACR 12V DC 500A Automatic Charging Relay with Manual Control
  3. Jul 1, 2016 at 3:44 AM
    Axion
    Axion Well-Known Member
    Adam
    Midwest
    daily driver with extra flexibility
    various odds and ends
  4. Jul 1, 2016 at 9:34 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I put the house battery in the bed, in front of the driver side wheel well. Used 1/0 gauge wire to connect a Blue Sea ML-ACR (7622) to manage charging and isolation. Works very well.
  5. Oct 29, 2019 at 9:08 PM
    KTMlover
    KTMlover Member
    2003 Tacoma
    Supercharged, tub/35s. 63 swap, Icon 2.5s, air locker Rear, Front ausie locker
    What batteries did you go with?
  6. Oct 29, 2019 at 9:52 PM
    Digiratus
    Roaming the PNW
    The RedHead
