Dual battery wiring question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tahoetacoma, Nov 1, 2014.
  1. Nov 1, 2014 at 10:48 PM
    tahoetacoma
    tahoetacoma [OP] Member
    Norcal
    05 Trd Offroad, 3inch, 35's
    sport hood, icon coilovers (w/ camburg uca's), icon rear shocks (w/ resi's), OME springs, 35x12.5 km2's, 17 inch atx thug, AP plate bumper, AP skid, AP fiberglass, beefed sliders, CBI rear (high clearance w/swingout), snugtop shell, k&n cai, ipod interface, warn 9.5xp (w/ masterpull synthetic), u-bolt flip
    I'm running 2 optima batteries in the bed of my 05 4.0L tacoma. I am using a perfect switch isolator one positive from the starter which is split into 2 positives (one main battery and one aux), with 2 150amp breakers (one for each battery after the isolator). There are 2 positive wires that run into the engine bay fuse box. One wire is black with blue stripe (this runs to the alternator). The other is a short black wire that ran from the + terminal of orginal battery to the factory 140amp alternator fuse. Do I need to retain this fuse even though I have 2 breakers in the bed. If I do delete this fuse will the fuse box still get power. Should have a third breaker between the alternator and the isolator. Any info will help!! If I wasn't clear please ask and I'll take photos or clarify.
    My yotas dead in the water until I finish the wiring so I really appriciate the help.
    Thanks Matt
