Dual color fog lights.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by taintedtattoo, Feb 26, 2024.
  1. Feb 28, 2024 at 7:13 AM
    #41
    eurowner
    eurowner Duke Sky
    Scoty
  2. Feb 28, 2024 at 7:13 AM
    #42
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Well, a block of cheese would probably have better light output. Ive seen these in real life once, and while I didnt get a really good look at them, they didnt look great. Beam pattern was kinda all over the place since they were trying to line up 8 beams instead of lining up just 2.
    RIX TUX likes this.
  3. Feb 28, 2024 at 11:50 AM
    #43
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Nice nice..and good call, Mix is one I haven't yet seen live. So much good stuff by him, it's kinda sad so few know anything much of him
  4. Feb 28, 2024 at 8:49 PM
    #44
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I was precise, everything I said was factually correct. You are correct in people are providing their personal experiences in a non-malicious manner, and they happen to be factually incorrect, the OP should be made aware of this bad misleading advice. Some of us are well vetted lighting experts and others are posting bad information about optically incompatible lighting product recommendations on a truck forum claiming it is close enough. If you dislike my feedback try posting in an actual lighting forum or group and see the results you receive. I will not apologize for calling out BS when I see it.
    Very curious on Rigid working this out with Toyota as an OEM supplier. I'll certainly look to pick some up as soon as they are available, no different than I did for Rigid's OEM TRD Pro LEDs.
    Ooff. No. Once again cheap Chinese garbage. Do you see how you can see the LED emitter in the lamp from the front? That means it has no pattern control. The lamp has no engineered optics whatsoever. It is a very low performing illegal flood light, it is not a "fog light" at all. Meaning it will blind everyone on the road, should never be used with other traffic and will be worthless in poor weather not to mention be pathetically low performing. Just another example of poorly designed products pointed out before. If you want a real dual color LED fog, the only way to go is Rigid.
    vicali, Laxtoy, Yossarian and 2 others like this.
  5. Feb 28, 2024 at 9:55 PM
    #45
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Appreciate you @crashnburn80!
    Having been a part of your testing process (headlights) and seeing firsthand the lengths you go to, to provide fair and honest feedback, I know you have no agenda, and are just providing non-biased data.
  6. Feb 28, 2024 at 10:01 PM
    #46
    MGMDesertTaco
    I'm still running the selective yellow SS3 Max fogs and wouldn't want it any other way. Paired with the oem led headlight conversion I did a while back everything is visible. The selective yellow really cuts through. :laser:
    Laxtoy and crashnburn80 like this.
  7. Feb 28, 2024 at 10:09 PM
    #47
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
  8. Feb 28, 2024 at 10:10 PM
    #48
    RIX TUX
  9. Mar 1, 2024 at 9:49 AM
    #49
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Agreed. Only grip is @crashnburn80 is just enabling me to spend more money lol. I swapped my Hid headlight bulbs (in retrofitted projectors) to Osram Nightbreaker Lasers and bought DD Maxx yellow fogs after reading his content.
