Dual colored rockers?
Discussion in 'OTRATTW' started by 4x4Taco09, Nov 20, 2014.
  1. Nov 20, 2014 at 9:36 AM
    4x4Taco09
    4x4Taco09 [OP] Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    Is there anyway I could order switches and instead of all white/white could I have say the top amber and bottom white? Or vice versa :D
  2. Nov 21, 2014 at 6:09 AM
    OTRATTW
    OTRATTW Well-Known Member
    Jim
    Cupertino
    We can build up the switches with the amber/white LEDs but there is additional charge per switch.
  3. Nov 21, 2014 at 6:24 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I have a dual colored one
    LOVE my OTRATTW switches!
    Still not done either! :D I'll have another order of 6 or 7 switches soon!
  4. Nov 21, 2014 at 7:24 AM
    jc1980
    jc1980 Well-Known Member
    MGM 4x4 TRD Off-Road (Extra Value Package II)
    See build link in signature or public profile.
    I wanted upper independent and lower dependent in white and at the time I wasn't able to find it on their website, but they did have it in blue, so I purchased the switches and changed it out myself (V1D1FBBB). You can put any color 5mm led bulb with a lip in there that you want (just make sure you note which side of the switch is + and - before you take out the old bulb and put in the new one).
    I still don't have the switches all wired to accessories though.
    http://www.thenewx.org/forum/showthread.php?t=56098 (How-to: OTRATTW (Carling Tech) Switches With Any Color LED) has a good writeup on it.
    Sandman614 likes this.
  5. Nov 23, 2014 at 8:05 PM
    4x4Taco09
    Dane
    Louisiana
    yea i may just order the all white ones and may swap one side to amber.
    for now ill just order the all white ones for now, thanks for the responses
  6. Oct 18, 2017 at 6:51 PM
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    for the dual coloured one, is that to say that the illumination of both colours stay on when the switch is selected? and when the truck is on but the switch is not hit, it only illuminates blue?0
    i wanna pull the trigger on two switches but im not sure what its going to look like when its all said and done.
    white while the switch is off, blue while illuminated.
    so far ive got:
    CONTURA V, FOG LIGHTS, LOWER LED INDEPENDENT
    • SPST ON/OFF switch.
    • Blue/White LEDs
    • Upper Blue LED is ON when the upper part of the rocker is pressed ON. This will light up the symbol area.
    • Lower White LED is independently wired. If connected this will light up the indicator bar.
    • Rated 20A 12V
    • No rear barriers between terminals. VCH housing connectors can be used with Packard 630 terminals. VCH connector and terminals are sold separately.
    • Insulated 1/4" female quick disconnect terminals can also be used. This is a 5 terminal switch
    • Wiring diagram
    Selected options:
    Custom Text:
    Etch: Vertical w/Indicator Bar
    Edit options
    AND
    CONTURA V, LED LIGHT BAR, LOWER LED INDEPENDENT
    • Blue/White LEDs
    • Rated 20A 12V
    • Wiring diagram
    in mind. thoughts? also it should be noted for illumination wise i have a white taco so, white/blue probably is the best colour scheme imo
  7. Oct 18, 2017 at 6:54 PM
    geekhouse23
    For my dual color switch, the blue is always on and the upper (zombie symbol) is on when I flip the switch on.
    mach1man001 likes this.
  8. Oct 18, 2017 at 7:00 PM
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    oh so you went with upper independent?
  9. Oct 18, 2017 at 7:16 PM
    geekhouse23
    Here is the description from my order way back in the day
    "V1D1JCBB-PZCZL-5ZL-ZOMBIELIGHTS, RED DEPENDENT TOP, BLUE INDEPENDENT BOTTOM"
    Manfred[QUOTED] likes this.
  10. May 25, 2020 at 5:24 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    This is exactly how I want my switches
