Dual Cyclone Dome Light – Interior Lighting That Works as Hard as Your Tacoma
Discussion in 'KC HiLiTES' started by Robert@KCHiLites, May 6, 2025.
  1. May 6, 2025 at 3:32 PM
    Robert@KCHiLites
    Robert@KCHiLites [OP] Robert Byrd @ KC HiLiTES Vendor
    Robert Byrd
    Flagstaff AZ
    2022 Tacoma
    KCHiLites
    We’re excited to officially launch the KC® Dual Cyclone Dome Light Bundle, a rugged and customizable interior lighting solution designed for everything from weekend trail rigs to fully built overland Tacomas.
    This dome light bundle uses two Cyclone V2 LEDs mounted inside a cast aluminum housing, with an IP65-rated sealed push-button switch that’s clean, compact, and easy to operate—even with gloves on. It mounts to tubing (like bed racks, bed bars, cages, and roof rack supports) using our ambidextrous 2-piece Clamp Claws, available in 1.5", 1.75", 1.875", and 2" sizes.
    Highlights:
    • Dual LED light output with 25° offset angles for wide area coverage
    • Compact form factor with sealed amber halo switch
    • Secure clamp claws for common tubing sizes used on Tacomas and overland gear
    • Choose from amber, clear, or diffused LEDs with optional colored snap-on lenses
    • Internal pre-wired switch harness (extend wiring to your power/ground setup)
    What’s in the Bundle:
    • 1x Dual Dome Light Mount w/ Integrated Switch
    • 1x Compact Wiring Harness (~7.5")
    • 1x Pair of Clamp Claws (your choice of size)
    • 2x Cyclone V2 LED Single Lights (your choice of color)
  2. May 6, 2025 at 3:40 PM
    PilotBoy352
    PilotBoy352 Well-Known Member
    Tim
    Mesa, AZ
    2015 MGM DCSB (rip) now 2018 white DCSB TRDOR 6MT
    How do you mount this in the cab? I'm just curious
  3. May 6, 2025 at 3:44 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Well you probably don’t unless you have a cage.
    PilotBoy352[QUOTED] likes this.
  4. May 8, 2025 at 11:16 AM
    Robert@KCHiLites
    Robert Byrd
    Flagstaff AZ
    2022 Tacoma
    KCHiLites
    @JdevTac is correct these mounts are specifically for roll bar.
  5. May 8, 2025 at 1:15 PM
    PilotBoy352
    Tim
    Mesa, AZ
    Understood, thank you
