Dual Electrode Plugs
Discussion in '1st Gen. Tacomas (1995-2004)' started by EJBTacoma02, Jun 23, 2014.
  1. Jun 23, 2014 at 10:06 AM
    EJBTacoma02
    EJBTacoma02 [OP] Member
    Erik
    Hampton, VA
    02 PreRunner SR5 4 Door
    When replacing spark plugs, do I need to use dual electrode plugs?
  2. Jun 23, 2014 at 10:15 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Short answer, no. But if you use a single electrode plug, you will have to replace it half the recommended miles (if its a 30k mile plug, you will need to replace it every 15k miles). Dual electrode plugs will be cheaper in the long run.
    Long answer:
    The Tacoma uses a wasted spark ignition system. Without boring you in the details, basically your plug sparks twice, once during combustion and once during the exhaust stroke. The exhaust spark is considered a "wasted" spark as it doesnt have any effect on anything.
    The down side is your plugs wear twice as fast. The dual electrode plug doesnt offer any performance gains but rather has twice the surface area to wear down, hypothetically lasting twice as long as a comparable single electrode plug, or in the case of a wasted spark ignition system, last just as long as a comparable single electrode plug.
  3. Jun 23, 2014 at 10:55 AM
    EJBTacoma02
    Erik
    Hampton, VA
    Thanks for the info, but I just finished replacing the plugs on my 02 with single electrode plugs and it has a rough idle? I did everything as I was supposed to. I'm confused as to why it would be idling rough?
  4. Jun 23, 2014 at 10:57 AM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Could be the spark plugs. Try replacing them with dual electrodes and see what happens. Heard of weird stuff happening. Also be sure you didn't leave anything unhooked or hooked the wires up incorrectly. Check and make sure your vacuum lines are connected properly.
  5. Jun 23, 2014 at 11:28 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    It has nothing to do with single or dual electrode. Might be gapped wrong. Could also be too hot or cold. What plugs did you use?
  6. Jun 23, 2014 at 11:37 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    ditto on the gap, did you check them before install...?
    I just replaced mine with the denso dual electrode, not all the plugs were the right gap, even with the plastic cone protector from the factory....
  7. Jun 24, 2014 at 5:34 AM
    EJBTacoma02
    Erik
    Hampton, VA
    Thanks for all the help. Gap is good on all the plugs. Went back and double checked everything and realized I had two wires wrong. I was sure it was correct but alas I was not.
    Truck is running great. Thanks!
  8. Jun 24, 2014 at 8:56 AM
    2000GTacoma
    Snow Hill NC
    Good to hear it was something easy.
