Dual exhaust= bigger spare wont fit
Discussion in 'Performance and Tuning' started by Coyboy 0351, Oct 28, 2011.
  1. Oct 28, 2011 at 12:50 PM
    Coyboy 0351
    Coyboy 0351 [OP] Well-Known Member
    MINNESOTA
    Sport Dbl Cab 4x4
    OME 3'' w/ OME nitro sport shocks.. 2'' blocks rear w/ OME sport shocks.
    Has anyony had the issues with Flowmaster American Thunder Dual exhaust and a bigger spare tire not fitting un the truck?
  2. Oct 28, 2011 at 12:56 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    A 285 tire would be a tight fit. When I had my american thunder, I had to pull the tire back towards the bumper after every 3 or 4 cranks of the cable so my 265 spare tire would tuck above the pipe, and then pull it back while I snugged the cable to keep the tire off the pipe. There isn't much room.
  3. Oct 28, 2011 at 12:56 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    whats wrong with duals on a truck? :stirthepot: :D
  4. Oct 28, 2011 at 12:58 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    You could have the exhaust exit before the rear wheels or have them exit the bedsides. I haven't seen that on a Tacoma, yet.
  5. Oct 28, 2011 at 12:58 PM
    oZmonKey
    oZmonKey Big Metal Hubajube
    Northern Colorado
    Black 98
    Unknown Spacer Lift.
    You could do something like this:
    If you don't mind your truck looking absolutely ridiculous.
  6. Oct 28, 2011 at 1:02 PM
    Stubbs95tacoma
    Stubbs95tacoma Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    Stacks arent stupid if they are on a diesel
  7. Oct 29, 2011 at 7:04 AM
    Coyboy 0351
    MINNESOTA
    Sport Dbl Cab 4x4
    Well HELL.... Called flowmaster yesterday and the guy said thats why we dont recommend the dual exhaust if you plan on using bigger tires... I said thats nice of you to mention that now, seeing as just before I ordered it I mentioned that the exhaust was the first step before the lift it and get bigger tires. #@$%
  8. Oct 29, 2011 at 1:31 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    MJ fits a full 285 spare with dual exhaust.
    I saw him do it at a mod day..I think Jlee cut the tabs off if I remember right and they had to guide it up..but his exhaust is like within 5/8ths an inch from the tire lol
  9. Oct 29, 2011 at 3:11 PM
    Coyboy 0351
    MINNESOTA
    Sport Dbl Cab 4x4
    Thinkin maybe I could angle it and wedge it to keep it angled so i can tighten it up. Use some header wrap on the exhaust pipe just insulate the heat from the tire... I am just gonna have to get under and dick around with it next week... Gives me an excuse to have a few of the boys over help and drink some beers!
  10. Oct 30, 2011 at 9:18 AM
    DevilDogTacoma
    DevilDogTacoma Well-Known Member
    Maryland
    2010 Tacoma V6 DCSB
    Flowmaster 40 Muffler, 15% Front Window and Windshield Sun Strip Tint, Antennax 14" Antenna, OME 3" Lift w/AAL, SlimCubby 6000K HID headlights and foglights, Thule tailgate pad for surfboards, 285/70/17 Nitto Terra Grapplers on 17x9 XD Addicts, LED map, dome and tag lights
    the guy who did my flowmaster muffler recommended not going dual exhaust because the driver side pipes have to be fitted around the spare tire and its either a tight fit or it can be hit by the leaf springs/axle going over bumps. have you had problems with that?
  11. Oct 30, 2011 at 1:32 PM
    Coyboy 0351
    MINNESOTA
    Sport Dbl Cab 4x4
    It will fit but the tire touches the tail pipe... I got to get it atleast 1/2 in away from the pipe.
  12. Oct 30, 2011 at 6:54 PM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    What about re-routing the piping so it goes around on the other side of the axle and then over the axle on the drivers side like it does on the pass side?
  13. Oct 30, 2011 at 7:05 PM
    gtdad66
    gtdad66 Well-Known Member
    Jesse
    West Ga
    2017 Tacoma Limited
    Front window tint, tool box, bed mat
    i like my magna flow exhaust. not duals but sounds great to me.
