dual exhaust question
Discussion in '1st Gen. Tacomas (1995-2004)' started by devinzz1, Aug 7, 2015.
  1. Aug 7, 2015 at 2:27 PM
    devinzz1
    devinzz1 [OP] Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    i want to true dual my exhaust on my 3.4 (why? for shits n gigs) and was wondering where id put the o2 sensor.
  2. Aug 7, 2015 at 3:45 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    I would just leave it on the side it is on now, then you don't have to move any wires and its easy to undo if you decide to go back stock later.
    I will say that every dual exhaust 6 cylinder I ever heard sounded silly and made me laugh every time I heard it, but some people like it just because it makes more noise even if the noise sounds weird
    DustStorm4x4 likes this.
  3. Aug 7, 2015 at 3:58 PM
    devinzz1
    devin
    2023 aclb trd or mt
    it will exit same place it is now. i guess sound is a personal preference kinda deal but ive heard a 4l taco and 4L ranger with true duals and i liked the way they sounded. Not even looking for a louder exhaust. just a different sound. il still have the single exhaust to put back on.
    MadDaddy likes this.
  4. Aug 7, 2015 at 4:01 PM
    keakar
    karl
    louisiana
    I guess its what you are used to and it sounds nothing like a v8 with duals so I guess that's why I think it sounds funny
    I guess its just because I am old fashioned and used to the deep throaty muscle car dual exhausts
    I suppose picking the right mufflers for it is the biggest part of getting a good sound out of them
  5. Aug 7, 2015 at 4:09 PM
    devinzz1
    devin
    2023 aclb trd or mt
    was thinking a dual in dual out magnaflow with the built in x pipe
  6. Aug 7, 2015 at 4:15 PM
    keakar
    karl
    louisiana
    I agree, its best if your going to do it, then do it right and have separate isolated pipes that never meet.
    if your not doing that then just put a 2 into 1 wye after the muffler to run two tail pipes out the back
  7. Aug 7, 2015 at 5:17 PM
    devinzz1
    devin
    2023 aclb trd or mt
    in an x pipe the seperate gasses stay on their own paths for the most part but the pulses interacting help with scavenging. a single pipe from headers with a 1 to 2 muffler is what i consider "fake" duals.
  8. Aug 7, 2015 at 5:20 PM
    4thone04
    4thone04 Well-Known Member
    jcl
    west END of hwy2
    new at 155,000
    Yes doooo it. And tell us how it worked. Most 6es that I have put separate pipes on have worked great. 911,svx,2.8 Chevy . I think a 6 runs better , the one exception was an odd fire Buick in a jeep. The stupid thing had to have a x pipe.
    But put quiet mufflers on it!!!
    Good luck
  9. Aug 7, 2015 at 5:35 PM
    keakar
    karl
    louisiana
    so your crossing them after the cats and before the muffler to "share" the exhaust back pressures?
  10. Aug 7, 2015 at 5:46 PM
    devinzz1
    devin
    2023 aclb trd or mt
    keeping separate from the crossover.
  11. Aug 8, 2015 at 10:15 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    The pulses from the firing cylinders help scavenge(pull out) the exhaust from other cylinders as the exhaust valves open. Goin to true dials can effect the timing of these pulses causing them to be less efficient at scavenging. Adding an H or X pipe is supposed help keep these pulses in tune to better scavenge exhaust.
    only negative that might happen going to duals aside from the sounding weird would possibly be a loss of power in the bottom end or lower rpm range.
    fireman1073 likes this.
  12. Aug 8, 2015 at 10:18 AM
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    dont do it
  13. Aug 8, 2015 at 5:33 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    I have single in dual out.. with magna flow cat and exhaust
  14. Aug 8, 2015 at 5:59 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    An x pipe is actually MORE efficient than two separate pipes. Plenty of muscle cars use this approach, like the ubiquitous V8 mustang. There's much to be said for cross-pulse tuning. A V-6 might benefit even more since there is 240 degrees of crank rotation between each exhaust pulse on a bank.
  15. Aug 8, 2015 at 6:08 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    V6 with duals.
  16. Aug 8, 2015 at 6:08 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Fine...Fine... lets call it trueish duals?
  17. Aug 8, 2015 at 6:13 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    Redneck pipes on a yota :headbang:
    I've seen duals done on the 3.4 and it sounds decent, but i personally prefer the single pipe exhaust
  18. Aug 8, 2015 at 6:14 PM
    devinzz1
    devin
    2023 aclb trd or mt
  19. Aug 9, 2015 at 7:07 AM
    keakar
    karl
    louisiana
    lmfao :rofl: but im not surprised they did it, it definitely has a cool factor to it :p
  20. Aug 9, 2015 at 7:12 PM
    RobertHyatt
    Robert
    Birmingham AL
    I'd consider a mustang as "true duals". An x-pipe actually improves performance over two completely separate pipes. Ditto for h-pipes. It is all about using the pulses to help scavenge opposing bank cylinders. I would therefore not think of an x-pipe as some sort of "step-down" from two separate pipes, rather it is an improvement.
