dual fuel tanks?
Discussion in '2nd Gen. Tacomas' started by ohdrj1all, May 4, 2011.
  1. May 12, 2011 at 8:45 AM
    #41
    malander
    malander That's some tight butthole
    max
    Missouri
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Are we still talking dual tanks or just a bigger replacement?
  2. May 12, 2011 at 8:46 AM
    #42
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
  3. May 12, 2011 at 9:10 AM
    #43
    chich2000
    chich2000 Well-Known Member
    AZ
    Tacoma 4WD TDR
  4. May 12, 2011 at 9:46 AM
    #44
    whippersnapper02
    whippersnapper02 Well-Known Member
    Christian
    Yorba Linda, CA
    10 MGM TRD OR 4wd Auto DCSB
    Banks Monster Exhaust, Pop n Lock tailgate lock, Hook-Ups tie down brackets, USA Spec Ipod adaptor, WO seat covers, color matched grill with Grillcraft insert, Tuffy locking bed box
  5. Feb 13, 2013 at 5:26 AM
    #45
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed
    If you put the spare tire in the bed or on a bracket off the back then a tank from any full size Jimmy or Blazer(1973-1991) will fit in there and you could use the skid plate that comes with them as well. As to switching back and forth, there are switches used on dual tank motorhomes that switch everything over between tanks(power for pump, sending unit, gas and return lines). Might also want to look at the old saddle tanks on a short box chevy.
  6. Feb 13, 2013 at 8:25 AM
    #46
    Barbaro
    Barbaro Active Member
    06 PreRunner DCSB Indigo
    Have you ever thought about a marine fuel tank? Yes they are stainless steel and expensive, but you could probably get one custom made if you wanna fit it under the truck. You are going to have to buy an expensive fuel pump and drill some holes (I dunno how comfortable you are with that).
    I've thought about this and if you put it in the bed you could just use gravity and let that magical force fill your existing fuel tank until the one in your bed is empty.
    You could split the fill-up hose that connects to existing tank with the one in the bed with a one way Y-valve and there you go no pumps or switches needed.
    The bed tank would also be out of the way from potential hazards like rocks and tree stumps.
    In reality I would just buy some Rotopax and attach them to the bed rails and call it a day. Put them in when you need them, take them out when you don't.
