Dual LED switch wiring help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DarthBane, Dec 6, 2018.
  1. Dec 6, 2018 at 12:58 PM
    DarthBane
    DarthBane [OP] Well-Known Member
    Toronto, ON Canada
    07 SR5
    howdy
    I just received a dual switch that I want to use to operate both front and rear accessory lights. Of course it was an eBay special and there are no instructions.
    I assume the black is negative. But what about the other colored wires? I’m assuming the red/purple go to the relay for the spot lights and the green and yellow to the relay for the rears.
  2. Dec 6, 2018 at 1:02 PM
    yellow_bandit
    yellow_bandit Well-Known Member
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    From what I've experienced, black is ground, red is hot, blue is illumination, green is to the circuit, yellow is probably to the other circuit. By circuit I mean the lights you are trying to power.
  3. Dec 6, 2018 at 1:04 PM
    DarthBane
    Toronto, ON Canada
    07 SR5
    I just tested with a 9v battery. The yellow is the switch illumination. Ugh.
  4. Dec 6, 2018 at 1:10 PM
    yellow_bandit
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    Welp that throws my info out the window. Sorry I couldn't be of more help.
  5. Dec 6, 2018 at 1:10 PM
    txtaco87
    txtaco87 Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    First time seeing a two-in-one switch like that :confused:
    If you don’t have an aux panel then make that diagram the battery and use an inline fuse
    0F1F1B44-8F09-440B-A947-D5AC43615AA7.jpg 180023CA-D257-4462-8AC3-B77FEB37F87B.jpg
  6. Dec 6, 2018 at 7:45 PM
    caribe makaira
    Caribbean, Puerto Rico
  7. Dec 6, 2018 at 7:58 PM
    DarthBane
    Toronto, ON Canada
    07 SR5
    Perfect. Thank you
  8. Dec 7, 2018 at 10:49 AM
    caribe makaira
    Another option...for ON at anytime.
    txtaco87 likes this.
  9. Dec 7, 2018 at 10:51 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Do you have a link for that switch? I have a friend that needs something EXACTLY like that.
  10. Dec 7, 2018 at 1:01 PM
    caribe makaira
    Google - Dual Spot Driving Light Bar Switch
  11. Jan 19, 2019 at 7:01 PM
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    I just got done doing a review on these types of witches. here's is a link with a few different sourcing options.
    https://www.tacomaworld.com/threads/dual-switches.588435/
