Dual Rear Calipers
Discussion in '1st Gen. Tacomas (1995-2004)' started by Elijahsleeper, Jan 23, 2023.
  1. Jan 23, 2023 at 2:32 PM
    Elijahsleeper
    Elijahsleeper [OP] Member
    2003 Toyota Tacoma
    URD Short throw shifter, Vortex cold air intake, upgraded performance headers, LED ditch lights with wire harness, upgraded headlight bulbs, aftermarket stereo system, billet aluminum shift nob, Rugged floor mats, plastic bed liner, ceramic clutch, oversized injectors with ECU tune... Lots more to come.
    I want to install dual rear calipers on my first gen. Tacoma. The second set of calipers will be connected to a hydraulic hand brake. The problem is I can't find a mounting bracket...
    Has anyone else already done this project? Does anyone know where to find mounting brackets?
    See linked video for an example. https://www.youtube.com/watch?v=gjqeFEyaUxc
  2. Jan 23, 2023 at 2:40 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    There is a company that sells a conversion kit. It's pricey. It uses parts of an FJ if I recall, and keeps the e brake in tact. There is no real-world braking performance benefit to installing rear disc brakes on these trucks.
  3. Jan 23, 2023 at 2:42 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
  4. Jan 23, 2023 at 2:47 PM
    Elijahsleeper
    2003 Toyota Tacoma
    I just want the added option of power sliding using braking for acute angle turns. As of now I transfer weight forward as I initiate the turn to unsettle the back end and use wheel speed/steering to control rotation. This is the proper way to power slide but I just want another tool as an option since braking can be advantageous to induce a power slide at times (like when slowing down and rotating for a very acute angle turn).
    Its more for fun than for function. Ty
  5. Jan 23, 2023 at 2:56 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    You may find that most here (in the 1st gen forum) are function over form, with a slant towards off roading or what has become known as "overlanding". Gauging your posts, you might want to take a look over at the street trucks sub forum and see if they are more in tune with what you want to do with your truck: https://www.tacomaworld.com/forums/street-trucks.70/
  6. Jan 23, 2023 at 4:37 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Build your own brackets !
    For what you want I have seen it done you want the biggest rotors in diameter you can make work .
    The biggest calipers to apply to apply pressure over the largest surface area even so your going to have heat issues
    Being Honest using Drum brakes and a cable set up with a long lever will give better results.
    For what you want .
    have fun!
  7. Jan 23, 2023 at 4:42 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :popcorn:
    Bivouac likes this.
