Dual Screen Operation
Discussion in 'Technology' started by Hotdog, May 19, 2009.
  1. May 19, 2009 at 12:12 PM
    Hotdog
    Hotdog [OP] My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I run dual screens at home, and I'd like to set it up so that programs automatically open on screen 1 instead of the last monitor they were on. Anyone know of a way to do that?
  2. May 19, 2009 at 12:19 PM
    thecoldone06
    thecoldone06 Well-Known Member
    What Operating System are you using?
  3. May 19, 2009 at 12:21 PM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    I don't really know how you would do that in windows.
    Just out of curiosity, why?
  4. May 19, 2009 at 12:26 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I'm using XP with an nvidia graphics card.
    I use a monitor for my normal computing, but like to use a larger screen TV to watch movies on. However, sometimes I like to watch e-mailed video clips on my main monitor. If I am using the TV for watching TV, then I would have to go through and change the input. I'd rather the player just always opened in the monitor and then I could move it over.
  5. May 19, 2009 at 12:30 PM
    drew02a
    San Antonio, TX
    You could make it so the TV is just a duplicate of the monitor instead of a second monitor? If you decide to do that, just:
    Right Click the desktop
    Select Properties
    Select the Settings Tab
    Select your second monitor
    un-check the box that says "Extend my Windows desktop onto this monitor"
  6. May 19, 2009 at 12:32 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    hmmm...I'll give that a try. I've been using the dual view option which fits my needs very well except for this one issue. I like that I can keep a different resolution for each monitor.
  7. May 19, 2009 at 12:32 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    yeah, I've browsed around in there, but I couldn't find any help.
  8. May 19, 2009 at 12:36 PM
    drew02a
    San Antonio, TX
    You can also:
    Right click the video player on the task bar
    Select Restore
    Right Click in task bar again
    Select move (will reposition your mouse exactly on the title bar of your video player)
    Click and drag back to your monitor.
  9. May 19, 2009 at 12:38 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    thanks. That sounds like it will work well enough.
  10. May 19, 2009 at 12:43 PM
    thecoldone06
    There's a program called UltraMon which will do this for you. There are lots of cool features but one is to add a tab to your properties menu which will allow you to choose which monitor to open that shortcut into. However the downfall is that you need a license to run it
  11. May 19, 2009 at 12:45 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    doh! I'll see about finding a similar, free alternative
