Dual sub enclosure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JeffBoyardee, Sep 5, 2022.
  1. Sep 5, 2022 at 4:55 AM
    JeffBoyardee
    JeffBoyardee [OP] Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
  2. Sep 5, 2022 at 5:03 AM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    They look nice. They say they are made from MDF and built solid. The volume is about right for that size box. Be sure to get a sub rated for the sealed enclosure. Also be sure to get a shallow sub, or watch the depth on the one you do pick. I have something similar and went Alpine to be sure it was not too deep. Another tip is to put a little pillow fill or something similar lightly packed in the open spaces , not directly behind the sub.
    The only thing I don’t like is I don’t see any mount hardware. It says it will drop in, which means it is easy to lift put by theives. Mine from taco tunes is bolted the the back. To get it out is a pain.
  3. Sep 5, 2022 at 5:08 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    Good point. Luckily, theft isnt a big problem in my area, I have a bad habit of leaving doors unlocked. But I'd probably find a way to bolt it down anyways. One thing I don't like, is there are no pictures of it installed.
  4. Sep 5, 2022 at 2:01 PM
    Danke5305
    Danke5305 Well-Known Member
    2013 tacoma prerunner
    got mine about 2 yrs ago, running some skar audio vd-10 in there. 2 things to watch out for, is air leaks which I would recommend just to recualk before putting it in who knows how long those have been sitting. second is the middle part that connects the two enclosures likes to reverb. I just ran up to a hardware store and grab some L brackets to fix it
