Dual transfer case questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by MtnRanchtaco, Mar 17, 2012.
  1. Mar 17, 2012 at 6:31 PM
    MtnRanchtaco
    MtnRanchtaco [OP] New Member
    CA central sierra foothills
    boondockin' wood haulin' fun 4x4
    NWOR tri-Y header & front springs,dynoflow super turbo muffler w/K&N filter
    Hi I have a "98" tacoma 4x4 it has the 2.7 w/ 5speed.What Transfer case do I have ?
    I have access to a "94" 4Runner 4x4 it has the V6 w/5speed.What Transfer case does it have ?
    Its saturday and Marlin is closed so anyone know if the "94"T-case is the same as the "98" T-case ?
    and if Marlin makes a kit for this set up or do I need a 1st gen. Transfer case ?
  2. Mar 17, 2012 at 7:57 PM
    valon5150
    valon5150 Well-Known Member
    Steven
    redding
    01 taco turd
    all pro lift, 33s, home made sliders, bumpers, skids
    From my understanding you can get the adapter plates and use an older toyota gear driven T case. Then re gear it to 4.7 if you want. Can't use another taco case though...Pretty sure at least.
    Your 98 has a chain driven drivers side t case. I THINK the 94 runner is a gear driven passenger side t case. If it is passenger side then it will work.
    Edit. 96 is when 4runner went to chain t case. So you should be good. I would get that runners case
    Pretty sure the 94's t case is the right one. use it, re gear it lower. get the t case adapter and tranny adapter plates from marlin/inchworm/trail gear and you're ready to put it in...well after shifters, new driveshafts
