Dual USB Outlet (Backseat\Cup Holder) Installation
Discussion in 'Technical Chat' started by montgomb, Nov 7, 2015.
  1. May 10, 2016 at 1:43 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I don't have a fucking clue about wiring.
    Only wiring I do is what I need to do for work and I'm not having to actually think about it.
    @Iggy. is a wiring wizard, but not sure he's around much at the moment. Just had a baby a few weeks back, but hopefully he'll chime in when he can.
    GARSHA91 and ramonortiz55 like this.
  2. May 10, 2016 at 1:44 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    OP has a pic of 10g wire, yet the add-a-circuit will only be 16g.
  3. May 10, 2016 at 1:44 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Thanks all, just don't want any electrical issues
  4. May 10, 2016 at 1:45 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Jesus. I don't think the door locks draw 20 amps.
  5. May 10, 2016 at 1:45 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    That is what I pulled out was a 20amp fuse
  6. May 10, 2016 at 1:46 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    I don't want to give you bad electrical advice, as I pull off a separate block. So I couldn't tell you for sure.
  7. May 10, 2016 at 1:47 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Agreed
  8. May 10, 2016 at 1:51 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Even following a chart like this
    That charger only puts out 3.1A. That's not a terribly high draw.
    Bravisimo likes this.
  9. May 10, 2016 at 1:53 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    That all looks Japanese to me brother. I hope someone chimes in to say whether having those 2 10amp fuses in the door fuse section is okay
  10. May 10, 2016 at 2:12 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Hey if I hear a pop I go up a fuse
    GARSHA91 and greeneggsnspam like this.
  11. May 10, 2016 at 2:12 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    The chart says your cable run should be more than enough for the ~3A
    Yeah. If the actuators are less than 10A you should be golden.
    Hopefully it works out for you and no :bananadead:
  12. May 10, 2016 at 2:25 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Hey Mr. electrical man @Up2NoGood any thoughts on my set up? When I installed the mirror kit from you we used the AC 7.5 fuse slot. So I just installed a dual USB in my truck in the rear of the console as in this thread. And used the door lock fuse which was a 20amp yellow fuse. I used a blade fuse holder and put 2 10amp fuses in it, Should I be good to go or will I need higher fuses???
  13. May 10, 2016 at 4:13 PM
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Are you guys wondering if tapping into the fuse panel is cool for an outlet?
    If so, I wouldn't do it. Usually people want the extra cig outlet for charging things (the two USB charger included) but if you want to power something else I would advise against it. My biggest thing is running too much power from the fuse panel. There's no sense in potentially frying that thing for $30 in parts.
    Here's what I would do, I would use the fuse tap to get power from the ignition so there's only power while the truck is running or the key is switched. Then I would run a "hot" wire from the battery to a relay. The relay would supply power to the cig outlet and the fuse tap would trigger it on or off.
    I know that may not make sense to some, but I could possibly wire something like this up for someone if they would like.
  14. May 10, 2016 at 4:23 PM
    T4RFTMFW
  15. May 10, 2016 at 4:26 PM
    #35
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Unchained 5150 and T4RFTMFW like this.
  16. May 10, 2016 at 4:53 PM
    #36
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Where would you suggest I move it to Mike??
  17. May 10, 2016 at 4:56 PM
    #37
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I know nothing about wiring, and everything you said makes no sense to Ricky sorry.
    T4RFTMFW and GARSHA91 like this.
  18. May 10, 2016 at 5:31 PM
    #38
    Iggy
    Northern CA
    Check out the build
    I can build you something? Just give me word and all you have to do is plug into the fuse and run a wire to the battery.
  19. May 10, 2016 at 6:21 PM
    #39
    Vegas Tacoma
    Vegas Tacoma Well-Known Member
    Brian
    Las Vegas
    06 prerunner sr5(RIP) 2018 Focus Hatchback
    I'd could use somthing like that @Iggy.
  20. May 10, 2016 at 6:23 PM
    #40
    T4RFTMFW
    His stuff is legit.
    Check his previous threads.
    @Unchained 5150 and @b.prall I can personally vouch for his work and his work ethic, he's local to me and worked on my truck and many others.
